Tonepad Phase 45 layout
Started by Celery_Strat, February 01, 2011, 06:17:52 PM
Celery_Strat
Anyone know if the pinout for the FETs is still backwards on the board layout?  I read that it was, but, it was quite an old thread.  Would certainly explain why my pedal ain't phasin'...
Govmnt_Lacky
Looks right to me. If you are using this layout:
http://www.tonepad.com/getFile.asp?id=70
Are you using Fairchild 2N5952s for your FETs?
Celery_Strat
Ok then, thanks!
Yes on Fairchild.  Got them from mouser.  (just bought 2 because i knew nothing about matching them.
Govmnt_Lacky
Quote from: Celery_Strat on February 01, 2011, 10:41:14 PM
Matching the FETs is a MUST in my opinion! Definitely read about and build the Geofx JFET matcher. You will probably need to order more FETs.
Good Luck  ;D
Celery_Strat
Thanks.
Yeah I found te schem for the matcher, but I'm not much on reading them yet.  I'm having trouble seeing how the opamp is connected.  I do better with layouts for now... :icon_mrgreen:  I can hear a ticking that is controlled by the knob, but, other than that, its just dry guitar signal...
Govmnt_Lacky
If you really want this fixed... follow this link:
http://www.diystompboxes.com/smfforum/index.php?topic=29816.0
After following the steps and posting what is required, you should have it up and working in no time!  ;)
Celery_Strat
Working on getting all those measurements now!  I'll be back in a bit!
