Single IC sample&hold
Started by Hides-His-Eyes, February 26, 2011, 05:28:00 PM
Hides-His-Eyes
http://www.futurlec.com/AnalogDevices/AD781JN.shtml
$10 a piece, but what could we do with this:
-clock the trigger for a bitcrusher; but there'd be horrific clock bleed...
-S&H filter; what happens if you feed an S&H with an LFO on the analogue and a non-matched clock; random S&H? How can we get a clock of random length pulses without a pic?
-Random trem? Random delay time?
-PICs are £1 vs $10... Does a £1 PIC have the hardware to do this job?
cloudscapes
Thats how the bugbrand bugcrusher does it. Theres a schematic on his site. Id google it but im on my phone ... :'(    i built a few samplerate reducers with this chip. I kept the clock noise down by gating the output with a vactrol setup. Another thing is that theyre bipolar supply. I used a max1044 for the negative power from DC
{DIY blog}
{www.dronecloud.org}
Hides-His-Eyes
Could you just bias it like an op-amp?
Wait, I just worked out how stupid that suggestion is. When you hold a signal, that's DC.  ::)
What does modulated bitcrushing sound like with an LFO?
CynicalMan
While this could be useful for simplifying layouts, IMO a analog switch or a MOSFET, a resistor, and a capacitor do a fine job for much less money.
soggybag
Looks like it wants to operate at +-10.8V. Not sure how to read that, but 9V might not b suitable.
cloudscapes
+ and - 9v is fine. I got it to work on just 9v and 0 once but damaged the sound. For good or ill
{DIY blog}
Hides-His-Eyes
Quote from: CynicalMan on February 26, 2011, 11:21:35 PM
I'm not familiar with that method, google didn't give it; do you have a link?
CynicalMan
This is the basic concept of a sample and hold:
That switch can be physical, or you can replace it with a MOSFET,
(the input buffer isn't always necessary, use at your discretion)
a JFET,
or a CMOS switch.
So, by tweaking these, you can get a sample and hold with three or four common components.
Hides-His-Eyes
I see; so the cap holds at the voltage into the high-Z input until it is discharged into or charged by the buffer?
What compromises have to be made on the cap type/value?
Do you want an even spaced clock or as low a duty ratio as the cap can cope with?
CynicalMan
It depends what you're doing. For bitcrushing, you want as small a sample time as possible, whether you're using the chip, or any of the capacitor sample and holds. That chip is probably just a buffer->CMOS switch->capacitor->buffer setup itself.
Hides-His-Eyes
Thank you for all your help here.
So when 'sampling', the input is just fed through? That's good.
I had one working in Falstad, which has given me some confidence, but I lost it before i could test to see the behaviour during the pulse.
N channel mosfet, right?
CynicalMan
An n-channel mosfet would hold at 0V and sample at V+, so that would probably be easiest.
