Dr Boggie (Need a parts list)
Started by Perkla, February 27, 2011, 10:27:31 AM
Perkla
Hello..
I am about to build a Dr Boggie pedal.. and i need a list with what parts i need to get to build one.. i have seen that there is several thoughts about different parts and i would like to get a list of what parts to use to get it to work best.
Is there anyone out there that have a partslist for Dr Boggie ??
oldrocker
Partlist for Dr. Boogey by electrictabs on gaussmarkov.net  (01.04.2007)
Part     Value          Library                    Part     Value          Library
C1       1uF            gm-caps-film-box           R1       2M             gm-resistors
C2       22nF           gm-caps-film-box           R2       1.8K           gm-resistors
C3       2.2nF          gm-caps-film-box           R3       2.2M           gm-resistors
C4       1nF            gm-caps-film-box           R4       680K           gm-resistors
C5       20pF           gm-caps-ceramic            R5       470K           gm-resistors
C6       1uF            gm-caps-film-box           R6       1.8K           gm-resistors
C7       22nF           gm-caps-film-box           R7       470K           gm-resistors
C8       22nF           gm-caps-film-box           R8       1M             gm-resistors
C9       1uF            gm-caps-film-box           R9       3.9K           gm-resistors
C10      6.8nF          gm-caps-film-chicklet      R10      330K           gm-resistors
C11      220nF          gm-caps-film-box           R11      220K           gm-resistors
C12      220nF          gm-caps-film-box           R12      1.8K           gm-resistors
C13      30nF           gm-caps-film-box           R13      10K            gm-resistors
C14      100uF          gm-caps-electro-pol        R14      4.7K           gm-resistors
C15      5nF            gm-caps-film-box           R15      2.2K           gm-resistors
C16      1nF            gm-caps-film-box           R16      100            gm-resistors
C17      220pF          gm-caps-ceramic            R17      100            gm-resistors
C18      220pF          gm-caps-ceramic            R18      68K            gm-resistors
C19      220pF          gm-caps-ceramic            R19      1M             gm-resistors
C20      100uF          gm-caps-electro-pol        BASS     100K-A         gm-pots
C21      .1uF           gm-caps-film-box           GAIN     1M-A (or 500K) gm-pots
D1       1N4004         gm-diodes                  MID      2.5K-B         gm-pots
Q1       J201           gm-trans                   PRESENCE 10K-B          gm-pots
Q2       J201           gm-trans                   TREBLE   25K-A          gm-pots
Q3       J201           gm-trans                   TRIM1    100K           gm-pots
Q4       J201           gm-trans                   TRIM2    100K           gm-pots
Q5       J201           gm-trans                   TRIM3    100K           gm-pots
                                                   TRIM4    100K           gm-pots
                                                   VOLUME   100K-A         gm-pots
Perkla
Can i use that parts to this pcb layout ?
Perkla
I am looking for pots ..
What does this means.. ?
Bass 100K-A  (What does A means ?)
MID 2,5K-B (What does B means ?)
A = LOG (logarithmic)
B= LIN (linear)   ..... thats what they are in the uk.....
do yourself a favour and do the gaussmarkov version...download the pdf and you will have the... pcb image,... the parts list...and the layout too...its a great great pedal..one of the very best  \m/   \m/  in my opinion... :icon_twisted:
also look at the top left of this screen and checkout DIY FAQ'S /GEO FAQS/ ...lots +lots of info...good luck. :icon_wink:
Perkla
Thanx for the information... but i didnt find any good pcb layout for the gaussmarkov... :S
Any suggestions about PCB layout... ?
Perkla
Awesome.... :D:D
Can i use the PCB layout at the bottom in the pdf file.. ?  i mean is it the real deal that is ready for printing.. ?  or do i have to re-size it.. ?
probably needs resizing...
rezize it to fit 100k trimmer pots and ya good to go!...
Perkla
Can i use standard blue 10mm trimmers.. ?  or do i have to use 5mm mini-trimmers.. ?
whichever fits your pcb image....as long as they are 100k's...
Perkla
ok.. thanx.. i am about to order the components i need to build Dr Boogie... and some other pedals.. :D
So i will start with the cirvuit board as soon as i have the stuff.. :D
I belive that Dr Boogie is a damn good pedal.. with a pretty wide range of gain.. ?  maybe one of the best.. ?
Perkla
Hey man... sounds AWESOME...  :icon_razz:  great playing to.. :D
There is a big difference between a tube amp and a non-tube amp..
I have a Marshall MG15 MS-II ministack... it sounds pretty good as well.. :D
yeah you wont be disappointed..i use mine on my marshall coz the marshall distortion is good...but very very hissy..when not playing...
these are nice even with the volume rolled back too...good luck with it man... :icon_wink:
Perkla
Thanx.. i hope i will be able to build the Dr Boogie... i mean its a advanced thing to do i belive.. and not recommended for beginners.. even if i have built lots of pedals like DOD 250 and stuff like that.. i find the Dr Boogie confusing.. haha...
Often i play around with different capacitors or diodes and resistors to get the sound i wanna have.. and it works great with a DOD 250 pcb for example.. but not even close to the sound that a Dr Boogie delivers.. :S  so thats why i thougt i give it a try.. :D
