WANTED: MXR M-117 Flanger gut shots!!
Started by Govmnt_Lacky, April 13, 2011, 10:16:25 AM
Govmnt_Lacky
I know this is a long shot but I figured SOMEONE out there could help  :icon_biggrin:
I need a gut shot of the original MXR M-117 Flanger. The Black unit with hard-wired power cord. (NOT the EVH model)
In particular, a good shot of the wired connection between the pots and the circuit board  ;D
I would like to verify some suspected errors in a layout that I am working from and I cannot find ANY pictures of the pot wiring.
I appreciate the help!
I generally find gut shots of most things I go looking for if I enter the name of the pedal into Google and do an image search.
beavis audio, in fact, has a very nice assortment of gut shots: http://www.beavisaudio.com/gg/mn.htm
Govmnt_Lacky
Quote from: Mark Hammer on April 13, 2011, 12:05:03 PM
I spent a while on Google today Mark. Unfortunately, I did not find any gut shots showing what I asked for  ;D
Quote from: Govmnt_Lacky on April 13, 2011, 10:16:25 AM
Govmnt_Lacky
Still trying to get some good pictures of the wiring between the pots and the circuit board. Someone HAS to have one of these  :icon_confused:
Govmnt_Lacky
Thomeeque
Maybe I am missing something, but why you cannot do that using schematic? T.
Govmnt_Lacky
Quote from: Thomeeque on April 14, 2011, 07:15:54 PM
It is not a matter of how the wiring CAN be. I can just switch them around if I want to.
It is a matter of how the wiring is SUPPOSED TO BE.
I suppose that after analyzing the circuit, doing the math, and studying the flow... someone could tell which way it should be wired but, I am not proficient at that and was merely seeking some answers with pictures.
In a picture of an original unit, I can match the wire color in the picture with the wire colors on the schematic and BOOM.... I know exactly how it should be wired.  ;)
I am quite surprised that NO ONE seems to have this information or even a pic of the wiring  ???   ???   ???
Seven64
i think it was in the link posted above
Thomeeque
Ice-9
I was thinking of that very same schematic Tomas but i couldn't find it, I know i had it somewhere.
@ Govmnt Lacky, this schematic has the wire colours included so wiring should be easy for you.
www.stanleyfx.co.uk
Govmnt_Lacky
#10
Quote from: Thomeeque on April 15, 2011, 04:15:59 AM
Quote from: Govmnt_Lacky on April 14, 2011, 09:51:56 PM
Have you seen this schematic?
Quote from: Ice-9 on April 15, 2011, 04:52:22 AM
Gentlemen,
I have that schematic already. I have seen it many times. I am not repairing an old unit. I am building from a layout that has possible errors on it (Shredaholic) and need to be able to translate the proper wiring by comparing the wire colors in a picture of a legacy unit to its schematic.
Here are my questions:
On the MANUAL pot in the schematic. What lug should the +15V input go to? What lug should GND go to? How can you tell just by looking at THIS particular schematic? Is there a "standard" way to wire pots/trimmers in a schematic?
Thomeeque
#11
Quote from: Govmnt_Lacky on April 15, 2011, 08:08:42 AM
IMO you cannot, you are right - you need to know something more about the circuit what is not on the schematic, they did forgot to mark CW sides.
EDIT: Maaaybe if you have middle lug leading down, CW side is on the right.
EDIT2: Nope, SPEED pot seems to break this "rule" :icon_frown:
Govmnt_Lacky
#12
Quote from: Thomeeque on April 15, 2011, 08:20:15 AM
This is why I wanted the picture of the wiring from pots to circuit board. It is the easiest way to remedy the issue.  ;)
I already know that the SPEED pot is wired to have the wiper lug (Lug 2) wired to Lug 1. However, I do not know if that thinking or orientation would translate to ALL of the pots.
Thomeeque
Quote from: Govmnt_Lacky on April 15, 2011, 08:22:39 AM
WIDTH - brown is CW
REGEN - purple is CW
SPEED - R19 side is CW
MANUAL - ?
Do you need info about trimmers as well?
T.
Govmnt_Lacky
Quote from: Thomeeque on April 15, 2011, 08:33:17 AM
WIDTH - brown is CW
MANUAL - ?
T.
No... don't need the trimmers.
Unfortunately Tomas... The ONLY pot that I really need answers for is the one you have no answer for  :icon_cry:
The MANUAL pot.
PICTURES ARE WORTH A THOUSAND WORDS! In this case, many words from quite a few forum posts!  :icon_cool:
Thomeeque
Quote from: Govmnt_Lacky on April 15, 2011, 08:37:21 AM
Of course, if there was a nice clear picture in the first reply, I would not say a word ;) but after almost two days of no success I thought it's maybe good idea to try another approach :)
I bet there is somebody, who could and will tell you soon or later, how should be MANUAL pot wired..
Good luck, T.
Fender3D
According to Dave:
Quote from: oldschoolanalog on September 22, 2010, 10:13:43 AM
I finally got a chance to take out some of my vintage 117's and really have a good listen. At extreme settings eg: man. control full CCW [slow clock/long delay], range full CW [max LFO] & high regen, things do get a bit noisy & "messy" [for lack of a better term] at the bottom of the sweep....
Then it should be as suggested on the other M117 thread here around:
lug 1 (full CCW) = GND
lug 2 (wiper) = to 100k resistor
lug 3 (full CW) = +Vcc
This will make you feel the control more intuitive, since it will set the lower point where the WIDTH control will start its coarse...
