Son of Screamer vero help
Started by DonB, May 10, 2011, 05:01:36 PM
DonB
Tony Forestiere
If you are talking about the top, just left of center, those would be the clipping diodes.
twabelljr
A good excersice is to print both the layout and the schematic. Start at the input of the schematic and trace it through the layout to the output. This helps to understand what all of the components are in the circuit and what they do. It will also help to spot a fault in a layout before it has been verified and you are debugging a circuit you have already built! The layout you linked to is a good one in this case. Here you can see the diodes are a 1n914 and a 1n34A.
http://www.geofex.com/Article_Folders/TStech/tsxtech6.gif
http://www.aronnelson.com/gallery/main.php?g2_view=keyalbum.KeywordAlbum&g2_keyword=Son+Screamer+Vero+Layout+4558&g2_itemId=44018
Besides, it is fun!  ;)
Shine On !!!
DonB
That might be a good idea...But i cant read schematics for the life of me...They make no sense at all.
twabelljr
QuoteBut i cant read schematics for the life of me
It will help alot. Just takes some getting used to and lots of reading. Start here:
http://www.geofex.com/Article_Folders/TStech/tsxfram.htm
The Tubescreamer is broken down and explained section by section. I had to read it quite a few times to get a grasp. In fact, read all the Geofex articles you can and the AMZ Lab Notebook to start. And of course read this forum and see what is going on with other peoples projects. A lot will be learned just by reading responses and following along. Check out the FAQ links and the Wiki also. If this bug bites you (sounds like it has) they will help. Sorry to ramble. Enjoy your project!
Shine On !!!
DonB
DonB
After some searching i have found what i was after.
