24V guitar amp
Started by iccaros, May 13, 2011, 09:15:55 PM
iccaros
Here is my Amp I have been working on. It runs on 24 volts and is not a plate staved design.  I wanted some input and not take up anothers thread.
I am changing the bypass caps on the pentodes, but still playing with values.
For this first version I used 2 12k5 in parallel (I did not have a PP transformer at the time)
and 2 12u7 as pre-amp
Here is the design missing the first 12u7 (you can substitute a 12Au7 as they are the same tube, with the 12u7 certified for 12v operation) , I am still working on that part.
here is a sample, build on bread board, so I get some noise..
iccaros
My build out so far :)
My first Chassis, I got a break @ harbor Freight
Still learning
After base Paint
zambo
I am loving that chassis! I need to get a break as well. I intend to build on of these amps soon.  ;)
I wonder what happens if I .......
iccaros
Quote from: zambo on May 13, 2011, 10:02:11 PM
got the 30" http://www.harborfreight.com/30-inch-bending-brake-67240.html
Had a 20% off coupon
Next is a drill press... And learning to paint..
  This seems to be prime example of "Just barely enough, none more approach removes the artifacts associated with higher intensity".
   Excellent soundclips, thank you for sharing amp build reports.
  I used to repulse listeners with high intensity amplification devices.
   This clip reminds me of when We used to have 'hot-westinghouse' jamms with tennis shoes and live-grounds. The featherweight speakers sitting on kitchen table would play all night, attracting rave reviews, no complaints.
  Less often as time goes by, a review puts new order to the list I've been attempting to make a low priority.
   Thank you for sharing the amplifier build reports !
  I noticed there seemed to be an absence of artifacts which I associate with high intensity amplification devices.
iccaros
Thanks... Glad someone liked my fumbling..  Will have the completed build done this weekend I hope..
I am working next on the 1 watt version.. I do not see it being much louder..  But will be push Pull and I am looking for a tube Rectifier for sag...  There are some 7 pin car version..
iccaros
Build with graphics...
I will update schematic and add video - sound tonight
iccaros
bluesman1218
It's all about the tone!
Steve
POPA - Plain Old Power Attenuator AVAILABLE for PURCHASE soon!
Silvertone 1482 rebuilt - switchable Tweed, tube reverb, Baxandall + / Little Angel Chorus build, tons of Modded pedals
iccaros
@all, the whole board :)
I want to add a line out or use this strait in for recording.. How would I do that.. Thanks
bluesman1218
Here's your Direct Out
Here's a really cool, and simple, mod. A Bright, Fat Full switch. You'll never want to play an amp without one, after you try it!
For a photo essay of my Silvertone 1482 rebuild, check out my photo album at http://www.facebook.com/pages/VintageToneUSA/201522306547361?sk=photos
Steve
iccaros
to review.. I am slow..
R2 and R1 come off my the speaker jack to a new jack :) yes
and for the fat/boost/bright
If I put a pot on the end of the switch to ground, would that be like a presence mod?
bluesman1218
Quote from: iccaros on May 18, 2011, 06:53:10 PM
R2 and R1 come off my the speaker jack to a new jack :) yes  YES
If I put a pot on the end of the switch to ground, would that be like a presence mod?   don't know, I'd have to look it up - been a long while since I did this.
Steve
iccaros
Thank you.. Will repost when I add the line out..
I am also trying to clean up the mids, may just go to the PP design for that..
El Heisenberg
Ive built this too. At first is was just the sopht amp version, but iccaros did the parallel 12K5 and gave me the tubes to try it out.
I have to fix my heater wiring. The 12AE7 is wired in series with the 12K5s which are wired parallel.
"Your meth is good, Jesse. As good as mine."
iccaros
Quote from: El Heisenberg on May 22, 2011, 08:50:00 PM
once that is done.. Any clips?
El Heisenberg
I have the cheapest mic radioshack sells. A 1/4 inch jack. Only way to do it is plug that directly into my 2001 compaq presario laptop and record with audacity.
iccaros
I use my cheap cam corder ( >$60).. and my phone.. so who am I to judge...
El Heisenberg
Ok but lemme work some things out.
Last nite i measured B+ and it was 16.8v. Heaters were at 10v!!! The 24v ct transformer wasnt enough. I bought a 24v ct 2A from radio shack and B+ was still too low. I lowered my RC resisor to 22 ohm 2 watt and now B+ is 24.5v . Heaters are at 12.6 tho.
In the sopht amp design i started with the rc resistor was 62 ohms.
