cloudscapes
it's a voltage reference. in this case half of the power supply generated by the two resistors and capacitor on the left. just connect all 5 Vb points together and you're good to go.
Logged
FWALS
Great thanks!
Logged
ayayay!
Wow! I don't think I've seen a pedal with so few grounds...  That alone begs it to be built. Should be really easy! What the heck is this anyway? Something synth-y?
Logged
The people who work for a living are now outnumbered by those who vote for a living.
tiges_ tendres
Steven M
Wow! I don't think I've seen a pedal with so few grounds...  That alone begs it to be built. Should be really easy! What the heck is this anyway? Something synth-y? It's a sample rate reducer. Kind of sounds like a ring mod. I built one but was largely unimpressed.
Logged
Try a little tenderness.
ayayay!
I'm a derp. I don't know what a sample rate reducer is unless it's one of those online mortgage calculators.
Logged
Gurner
They're there in spades... albeit virtual ones!
Logged
ayayay!
They're there in spades... albeit virtual ones! Oh yeah I know, I just mean the literal components to earth. Don't see that too often in pedals.
Logged
EATyourGuitar
ALL YOUR BASE ARE BELONG TO US
also fair to say that it can be called a sample&hold that goes up to audio rates. hence, therefor, hereto ::strokes beard:: why its a analog sample rate reducer and not the traditional analog>digital>analog converter with variable clock frequency.
Logged
FWALS
Wow! I don't think I've seen a pedal with so few grounds...  That alone begs it to be built. Should be really easy! What the heck is this anyway? Something synth-y? It's a sample rate reducer. Kind of sounds like a ring mod. I built one but was largely unimpressed. Hey what part did you use for the op amps?
Logged
MikeH
Mike H - Ann Arbor, MI
They're there in spades... albeit virtual ones! Oh yeah I know, I just mean the literal components to earth. Don't see that too often in pedals. They dont show it on the schematic, but you'll obviously need to ground the opamps. It's really not that different than other designs of similar complexity.
Logged
tiges_ tendres
Steven M
Wow! I don't think I've seen a pedal with so few grounds...  That alone begs it to be built. Should be really easy! What the heck is this anyway? Something synth-y? It's a sample rate reducer. Kind of sounds like a ring mod. I built one but was largely unimpressed. Hey what part did you use for the op amps? 2 4558's Any dual will do.
Logged
