cutting traces on veroboard
Started by mordechai, May 27, 2011, 10:17:19 AM
mordechai
Anybody have an easy way to cut the traces on the strip side of a vero board?  I guess I could just use an exacto knife, but I wonder if you have a preferred method that's a little quicker...
Ice-9
When I used to use Veroboard I remember having a little screwdriver shape tool but instead of  a screwdriver end it had a machined cutting end on it. One of the best tools i had at the time, saved me loads of frustration.
http://uk.farnell.com/duratool/3360568a/cutter-track/dp/3360568?in_merch=true&MER=i-9b10-00001422
www.stanleyfx.co.uk
ayayay!
The people who work for a living are now outnumbered by those who vote for a living.
Renegadrian
drill bit #3 (sound great, can be a perfume or a song!!!)  ;D
(3mm point)
digi2t
Quote from: Renegadrian on May 27, 2011, 11:42:39 AM
(3mm point)
I use a bigger bit, number 20 or so, with a hand chuck. Just turn until I chamfer out the copper.
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
artifus
drill bit by hand. only takes a few twists, no drill required.
Perrow
+1 for the Dremel, I use it with one of those diamond engraving bits, no problem cutting traces between holes.
3 or 4mm drill bit works for me.
Electric Warrior
vendettav
I actually use an exacto knife. ok it's like an exacto knife blade, i just filed my flat metal file's top edge lol anyways an exact knife works for me well enough, never encountered any problems
check my music HERE
Shredtastic psycho metal!
