potentiometer "W" stand for?
Started by wakeuptone, July 29, 2011, 09:48:48 AM
wakeuptone
Any one know potentiometer "W" stand for ?  (audio, linear, reverse) Thank you.
bean
From left to middle it's reverse audio, from middle to right it's audio. So, the middle portion of the taper is linear.
Steve Mavronis
This may help:
If you look at this pot taper comparison graphic below you can see in the bottom left graph when the W taper is at 50% rotation it is at half the total volume range. In the top left graph the A taper has to be at roughly 75% rotation or so to have equal volume output.
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
wakeuptone
#3
Thank you for all answer.
1) Where I can find "W" Potentiometer.?  or any alternative potentiometer?
2) "M" Potentiometer also anyone know stand for.  Is it same as "W"?
Steve Mavronis
Quote from: wakeuptone on July 29, 2011, 10:04:03 AM
No. Look at the graph in my post above.
wakeuptone
Vince_b
MetalGuy
Actually almost all  EQ's require W-taper pots/slide pots for smooth frequency adjustment otherwise the pot will have narrow sensitivity range at both ends.
runmikeyrun
Every DOD pedal i've ever opened has W pots... always wondered what that meant.  Thanks!
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
Brymus
Why would anyone use an "M" taper ?
Its hits 100% at 50% rotation,so half the dial is the same setting, full on.
MikeH
FiveseveN
Quote from: Brymus on July 30, 2011, 04:41:09 PM
So is the "N" taper, only the other side is "full on", or off. The point is to use them together, just as it says on the box: "For dual unit use".
Why? I'm sure there are applications that require such a strange thing but I haven't encountered one yet.
Paul Marossy
I've never even heard of a "W" taper until now!  :icon_confused:
Hides-His-Eyes
Looks similar to an 's' taper to me, so maybe W stands for "Wah"! ;)
DiscoVlad
Quote from: FiveseveN on July 30, 2011, 11:15:25 PM
They (Dual-gang M+N Taper) are used as left/right Balance controls in stereo circuits.
egasimus
^ idk, didn't this application require a dual-ganged log + reverse-log pot?
The image above solved for me the long-standing mystery of what 'D'-taper pots were, though. A shop in my town stocked them, and I never figured out what they were. Pity it's closed down now, there doesn't seem to be any place near me where I can buy audio taper pots anymore.
DiscoVlad
Quote from: egasimus on August 02, 2011, 05:16:12 AM
It is dual log/antilog, but only for half the rotation.
The idea of these potentiometers is that in the centre position the output is at maximum, and turning the knob either way attenuates one channel while leaving the other at a constant level.
