|AMPAGE| |GEOFEX| |AMZ|
May 18, 2013, 07:46:53 PM
890634 Posts in 97533 Topics by 28664 Members
Latest Member: jetmarshall
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  True Bypass - Why not ground the input AND the output? 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: [1] Go Down Print
Author Topic: True Bypass - Why not ground the input AND the output?  (Read 2204 times)
Suicufnoc
Brett N - Missouri
« on: August 09, 2011, 09:41:07 PM »
I've seen a lot of 3PDT True Bypass wiring methods that ground the Input of the effect when bypassed, but not the output.  Is there any reason not to do this?  (Other than the obvious hassle of adding a second jumper.)
Logged
Sticks and stones may break your bones, but words can get you shot
more
Re: True Bypass - Why not ground the input AND the output?
« Reply #1 on: August 09, 2011, 09:56:38 PM »
No particular reason why not. I guess the question I have is what is being achieved. Don't get me wrong - I like using belts and suspenders in parallel backup arrangements.
But if the input is grounded, the output is quiet unless the thing oscillates all by itself and can broadcast  its output across the switch gap that's open from the output to the signal lines. And if the output is grounded, internal oscillation could broadcast through the ether. Maybe a poor wiring job makes the power ground and signal ground share a line and current wobbling on the shared ground could get into the signal line. Grounding the input is probably a better way to keep the circuit quiet.
I've even seen setsups that ground somewhere in the middle of the effect circuit.
Given that hard-contact true bypass will always have some amount of clicking depending on how unlucky you are in where in the signal cycle the contacts close, I prefer one of the several other ways to bypass. And the Millenium C will let you mute as many places in the circuit you like.
Anyway, if it seems good to you, no reason why not.
Logged
West Texas Wisdom #37: You can't pour enough butter on a cactus to make it easy to swallow.
Suicufnoc
Brett N - Missouri
« Reply #2 on: August 09, 2011, 10:04:40 PM »
I've just heard of cases where extreme gain fuzzes or other pedals need the output muted(probably because of self oscillation as you said.)  I'll have to look into this millennium C.  I've Heard of millennium bypass, but not C.
Logged
darron
Melbourne, Australia
WWW
« Reply #3 on: August 10, 2011, 01:29:46 AM »
that's pretty cool. thoughtful.
i especially like how the input signal only has to pass through one switch to make it to the output bypass.
might have to give this a shot one day (:
Logged
egasimus
Adam
WWW
« Reply #4 on: August 10, 2011, 07:00:46 AM »
Here's what RG's talking about: http://www.geofex.com/Article_Folders/Millenium/The%20Next%20Millenium.pdf
However, I can't understand how this is used: how it is even connected to the actual effect circuit, as well as how to "mute as many places in the circuit as you like".
Logged
more
« Reply #5 on: August 10, 2011, 08:52:24 AM »
It connects to the circuit like the original Millenium: the control line connects to a DPDT switch wired in the special way shown in the original article, here:
http://www.geofex.com/Article_Folders/Millenium/millen.htm
The essence of the Millenium are that it is a very, very sensitive detector of the difference of resistance to ground of air and a real resistor. So it's connected to have the control line connected to the output of the effect when the effect is bypassed, and to be truly open circuit when the effect is running. The true open circuit causes the LED to come on. For this to happen, you need a device which provides a literally nano-ampere current and a switch device that senses that. Diodes are used reverse biased as a current source for the current, and a FET for the sensing device.
The Millenium C takes note of the fact that once you have anything that switches, you can use that switching action to trigger other things. For muting other places in the circuit, you take some device that can mute a signal - a FET, a CMOS switch, even a bipolar device - and trigger it to mute when the Millenium says " the effect is off now."  True, I didn't draw out all the possible ways to do it. Takes a long time.
Logged
acromarty
WWW
« Reply #6 on: August 11, 2011, 05:54:11 AM »
If the output is d.c. coupled then grounding it is not a good idea, you will short out the output.
In the best case this may only reduce your battery life, worst case it might damage the op-amp or transistors driving the output.
If it is a.c. coupled with a series capacitor then grounding the output should be ok.
Logged
Andy
darron
WWW
« Reply #7 on: August 11, 2011, 06:50:32 AM »
if there was DC on the output then it would pop like hell when you toggle the switch anyway, as R.G. recently reminded me.... so there's a safe bet that's not the case.
Logged
Pages: [1] Go Up Print
« previous next »
Jump to:
