Resistor Short
Started by soupbone, September 13, 2011, 02:59:53 AM
soupbone
When someone says "Short out the resistor" in a circuit,What does that mean exactly?Does it mean to remove the resistor,or to just clip the 2 leads?
.Mike
It means to connect one end of the resistor to the other end of the resistor, making the resistor the equivalent of a piece of wire.
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
soupbone
Quote from: .Mike on September 13, 2011, 03:10:59 AM
Mike
Hey Mike,So do you mean to put the resistor through the 2 holes on the pcb,and then solder the 2 ends together but not soldering it to the board?
.Mike
You can remove the resistor and put in a jumper wire.
Or, you can tack-solder a jumper wire from one side of the resistor to the other.
Mike
soupbone
