Author
Topic: Equinox: Easy PT2399 Reverb (Read 35376 times)
theundeadelvis
Ahren O., Bloomington, IN
You can just paste it in the address bar without the www. part (just start with freewebs.com). It will redirect to the appropriate address. Works fine for me in Chrome and Firefox
Logged
If it ain't broke... ...it will be soon.
askwho69
this is a reverb that i was looking for  opps found!  Thanks so much
Logged
"To live is to die"
John Lyons
Basic Audio
Thanks for the rehost Walt, cool circuit Merlin. Thanks for sharing!
Logged
I etched and drilled two boards last night, and am looking forward to stuffing them and firing them up. We have a government-wide charity drive for the United Way every year at this time, and in years past I've contributed a pedal to the fundraising auction. This year's contribution will be an Equinox, with whatever additional bells and whistles I can stuff into a 125-C. Thanks.
Logged
meffcio
Great, I was waiting for that. For this kind of reverb, AND for the pdf.  Since I have some pt's, I'll build this guy soon, and see for myself what is it capable off. But to be honest - vectorized pcb in the pdf would be much better (loseless).  Isn't the tracing software capable of exporting the board directly to the pdf?
« Last Edit: September 22, 2011, 02:57:46 PM by meffcio »
Logged
merlinb
Good question. I'll have to double check that...
Logged
dam28
Quick question: What's the point of transistor Q1? Am I right in thinking the output from the first opamp feeds into the input of the first PT? I just don't understand Q1.
Cheers! D
Logged
merlinb
Q1 in an analog switch. When the base is pulled low the transistor switches off, and no signal is passed to the delay line. This is how bypass with tails is achieved. You could also use a FET in this position, if the base resistor is replaced with a diode, which might look more familiar to you?
Logged
dam28
Interesting. So it's simply the bypass on the circuit? I could just feed the output of the op-amp into the input of the PT?
Logged
merlinb
Yes you could replace Q1 with a direct link, if you are using true bypass or something.
Logged
Paradigm X
Hi, thanks for posting this, I have 5 pt2399s and been looking for a reverb, perfect!
Minro query (bit of a noob, sorry), would this require any modification for use as line level (synths etc)?
Cheers,
Ben
Logged
therecordingart
If anyone is planning on etching a board...etch an extra and I'll buy it off of you.
Logged
dam28
Cheers for the advice Merlin!
Logged
merlinb
The delay line will handle 2Vp-p signals as it is. If you want it to handle larger signals then you would need to reduce R11 and increase R19 proportionately.
Logged
Paradigm X
The delay line will handle 2Vp-p signals as it is. If you want it to handle larger signals then you would need to reduce R11 and increase R19 proportionately. Thank-you.  If anyone in the UK (or elsewhere TBH) is making a PCB and can possibly make an additional one I'd be happy to compensate for materials, time and postage. Many thanks! Ben
Logged
asatbluesboy
Gustavo Santos
Baaaaaabyyyyy... Baby, baby, I am gonna leave yo-ou... I ain't joking, woman--I've got to ramble.
Awesome song from an awesome band. I can't recall any band having ever recorded such a perfect first album (ok, it's not the first since they were technically "The New Yardbirds", but anyways...).
Need. To. Build. One. Much more practical than hauling that AC-fed bitch Microverb II around.
Logged
...collectors together and emitter to base? You're such a darling...
ton.
dam28
Another quick question. R19 and C13 make up the feedback. When I don't connect these I just get two delays, as expected, when I connect the feedback though the circuit goes into crazy oscillation. This is expected also I guess but wonder if you know how to over come this? Get a the reverb to fade out gradually and not go mental!
Good build though. Really enjoying the design.
D
Logged
merlinb
It shouldn't oscillate... sure you haven't made a mistake somewhere? Did you change R11 maybe? Anyway, quick answer is increase R19 until it stops oscillating.
Logged
dam28
I'll give this a go later. It sounds quite cool but its a bit hard to control! Ill check my layout and keep you updated. Thanks again.
D
Logged
