Spray-painting PCBs
Started by egasimus, September 21, 2011, 11:35:38 AM
Beo
I usually use a flat spray paint on my PCBs... I like the aesthetic. I only spray the component side, after the board has been etched and drilled. I don't clean off rosin after soldering in the components... I try to use optimal heat setting and minimal use of solder, so that I'm not left with a lot of resin residue.
Marcos Camara
In Dyna Comp I used spray paint stained glass.
