|AMPAGE| |GEOFEX| |AMZ|
May 21, 2013, 04:02:23 PM
891180 Posts in 97586 Topics by 28683 Members
Latest Member: ebmvitreo
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  GTFO - Full tube high-gain pedal (2x 12AX7) 0 Members and 4 Guests are viewing this topic. « previous next »
Pages: 1 ... 3 4 5 6 7 [8] 9 10 11 12 13 14 Go Down Print
Author Topic: GTFO - Full tube high-gain pedal (2x 12AX7)  (Read 34094 times)
Hilli
Re: GTFO - Full tube high-gain pedal (2x 12AX7)
« Reply #140 on: March 12, 2012, 05:24:54 PM »
Hi.My english is not the best, but I will try it. I think I know what your problem is. You can see in the PCB!, not in the layout!!!, there is a big ground-plane that connects everything. The layout is for guidance only when you plant the parts.
And yes, I'm using Silva Mica's.
Greets
Logged
fair.child
« Reply #141 on: March 12, 2012, 05:45:02 PM »
Hey Hili, looks like awsome build,
I wanted to built this pedal too. Seems yours mod from the previous schematic is using Baxandall Theory. It is great idea to put into this pedal.
So, I want to asked about the R16 ,R17, and the rest (Pots,etc) question about your pedal. I still can't find where does it go. Could you please tell me ? I'm kind a confused here, and hope somebody will help me to built this pedal. I just need to know where is the ground pad of this Bad ass pedal.
If you don't mind, please share me about the grounding pad. I'm trying to understand the schematic and PCB, but I still can't found it.
And also, did you put a Silver Mica caps on C10 and C14 ?
Thank you Smiley
You can use anywhere on the ground plain for ground...  I would guess that silver mica caps would work fine for c10 and c14..
thank you for your fast reply Jim and Hili. I'm glad to know it
(Yeay my english too Hili, sorry about my poor english, kind a big confusion here, hope you'll understand)
Just to make sure I'm doing right and one the track.
here's what I think about this project
http://dl.dropbox.com/u/3891278/GTFO.png
About the Silver Mica's, Can I use a capacitor that has a lower voltage value of 2kV for silver mica? I think the capacitor has a less voltage han 2 kV, Does it still safe to use ?
I will think twice and read the BOM again for the HV caps.
Anyway, Thanks for your help Jim and Hili, Both of you're the person who help me to solved my confusion and insomnia about this silly question.... arggghhh Smiley I'm very pleased with your answer
Cheers
« Last Edit: March 12, 2012, 05:49:19 PM by fair.child » Logged
Hilli
« Reply #142 on: March 12, 2012, 06:00:31 PM »
And don't forget the jumper under IC1. First I had mounted the IC, than I saw the jumper... icon_redface  Grin
« Last Edit: March 12, 2012, 06:02:38 PM by Hilli » Logged
J0K3RX
Jim
« Reply #143 on: March 12, 2012, 06:06:23 PM »
Also fair.child, you asked about R16 and R17... I believe they have been omitted/left out of Hilli's modification. Please correct me if I am wrong Hilli and Great looking build by the way!!! I am wanting to do what you did with the full tone stack! I may try it tonight.. Thanks!
EDIT: Hilli - Any gut shots of your tone stack mod? Also it looks like you mounted the circuit board with screws from looking at the top of your pedal...? Would like to see where you located the screws/holes in the circuit board so that they did not get in the way of anything? I think I can guess but I like pretty pictures lol  icon_mrgreen Kinda tight inside my build...
~ Jim
« Last Edit: March 12, 2012, 06:17:55 PM by J0K3RX » Logged
If it sounds good, then it is good...
Hilli
« Reply #144 on: March 12, 2012, 06:17:55 PM »
You are right Jim. If you build with complete tone stack you do not need R16-R17 and the other stuff after C6. Maybe, if the signal is too loud, you can insert a 47K resistor (try out) from output to ground to reduce the signal.
Edit: I will send any guts tomorrow, first I must finish "remaining work details"  Grin
Edit2: The enclosure is not a Hammond BB, it is a JJ and a little bigger.
~ Bernd
« Last Edit: March 12, 2012, 06:26:17 PM by Hilli » Logged
J0K3RX
Jim
« Reply #145 on: March 12, 2012, 06:32:00 PM »
~ Bernd
Very cool Bernd!!! ah ha.. I thought your box looked a little bigger than mine!  I will be looking forward to it!  icon_wink Great mod as I was thinking of something like this myself... The tone controls on this did very minimal, maybe adds or takes away a little presence... Not to take away from the original pedal design at all because it still sounds awesome!!! I am guessing that the added bass/mid/treble will sound great and allow for better tone shaping!!
« Last Edit: March 12, 2012, 06:36:57 PM by J0K3RX » Logged
fair.child
« Reply #146 on: March 13, 2012, 02:19:30 AM »
Hey Jim and Hili, I have a few question again, hope you will answer me Smiley
I saw a pad between the fifth number from the tubes ? It is connected. What is the function of this pad ?
I give a red mark on it. I've realized it from the Jim previous post that it has a wire on it, so where it should go ?
http://dl.dropbox.com/u/3891278/GTFO.jpg
and can Silver Mica accommodate 2kV (HV) on this board ? Generally, this is a silly basic question, but I'm curious to know.
About the mods,
Please check this http://dl.dropbox.com/u/3891278/GTFO%20Mods.png, I'm quite doubt about my pots orientation, am I doing right ?
Again, just to make sure the mods are working
Cheers
« Last Edit: March 13, 2012, 03:05:37 AM by fair.child » Logged
J0K3RX
Jim
« Reply #147 on: March 13, 2012, 09:05:06 PM »
About the mods,
Cheers
That pad between the tubes that you have marked in red is for the 12v heater... I ran a wire directly from the 12v DC input to this pad.
The silver mica should be rated at 2kv, if not you may have problems... What are yours rated at?
Logged
fair.child
« Reply #148 on: March 13, 2012, 09:14:43 PM »
ahh, I see that, okay, thank you for your confirm Jim
so, the marked 5th pad is for the 12V DC heater
about silver mica, I believe mine should be rated under 2kV in my SM mark. It is around 500V. Is it still possible to use it ?
Cheers
Logged
Paul R. - Maine USA
« Reply #149 on: March 14, 2012, 11:21:36 PM »
Use 400V or 500V.
Just like real tube guitar amplifers.
Silver Mica was sometimes used in radio transmitters or TV sets at high voltage, so 2,000V Silver Mica used to be available.
ALL high-voltage work is out of style today, so some new SM is rated 50V.
This amp runs 100V-400V depending on your power supply. 400V-500V rated caps will be fine.
Logged
Hilli
« Reply #150 on: March 15, 2012, 12:39:29 AM »
And don't forget. Working with high voltage is dangerous and can be deadly. Be careful.
Logged
J0K3RX
Jim
« Reply #151 on: March 15, 2012, 04:59:00 PM »
No doubt! \\\SHAZAM///
Bernd, I was hoping to see some gut shots of you tone stack mod? If not that's ok...  icon_sad
My GTFO gets quite warm/hot after a while of playing... I was thinking to install a small fan on the front to expel the heat from the inside of the pedal..? Thoughts?
Logged
Paul R. - Maine USA
« Reply #152 on: March 15, 2012, 05:03:20 PM »
> Thoughts?
Tube stuff is supposed to run hot. Enjoy.
Logged
Ron R.
« Reply #153 on: March 15, 2012, 07:12:28 PM »
Beware the Ides of March.  Which is today.
Logged
Hilli
« Reply #154 on: March 15, 2012, 07:35:31 PM »
Sorry, I didn't had the time to make photos. I will send they in the next few days (tomorrow).
« Last Edit: March 15, 2012, 07:37:45 PM by Hilli » Logged
J0K3RX
Jim
« Reply #155 on: March 15, 2012, 07:47:51 PM »
> Thoughts?
Yeah, I know... Not really worried about the tubes themselves... I am more worried about the components trapped inside the box... Glad I got all 105c capacitors!
Logged
Hilli
« Reply #156 on: March 15, 2012, 09:50:50 PM »
Jim, did you make pictures?
Logged
J0K3RX
Jim
« Reply #157 on: March 15, 2012, 10:42:10 PM »
Logged
Hilli
« Reply #158 on: March 15, 2012, 10:52:58 PM »
Wow, Cool. How have you mounted the PCB? There are no holes....
Logged
J0K3RX
Jim
« Reply #159 on: March 15, 2012, 10:55:10 PM »
Ok, here is a "REAL sh*tTY" sound clip of it running direct with very slight delay and a mesa boogie cab impulse .... I am tired and just chuggin a little to let you hear the tone I am getting... Not trying to impress lol
I have an amp and I have ran it through it also and to me that is the way to go!! It really kix ass going into your amp in my opinion but my brother has my SM57 so direct it is for now...
Please don't laugh icon_redface
http://dl.dropbox.com/u/11178619/GTFO-1%20TEST1.mp3
Logged
Pages: 1 ... 3 4 5 6 7 [8] 9 10 11 12 13 14 Go Up Print
« previous next »
Jump to:
