Author Topic: 3: Build pictorial  (Read 172039 times)
0 Members and 2 Guests are viewing this topic.
aron
3: Build pictorial
« on: October 04, 2003, 03:56:41 AM »
I would load this page, then save it onto your hard disk using IE or Mozilla's save page feature.
It will take a while to load due to the pictures.
Good Luck!
NPN Boost Build
Raw URL just in case.
http://www.diystompboxes.com/beginner/build/npnboostbuild.htm
Please ask if you have questions!
Ice9Rg570
  • Guest
3: Build pictorial
« Reply #1 on: October 06, 2003, 03:05:22 AM »
so at the end it says just wires next...
where do the wires go from? im such a beginner...
aron
3: Build pictorial
« Reply #2 on: October 06, 2003, 03:15:31 AM »
No problem. Let me work on this part and post it.
Ice9Rg570
  • Guest
3: Build pictorial
« Reply #3 on: October 06, 2003, 03:18:20 AM »
Quote from: aron
 :D Thanks!
aron
3: Build pictorial
« Reply #4 on: October 06, 2003, 03:19:04 AM »
I'm working on it now.
aron
3: Build pictorial
« Reply #5 on: October 06, 2003, 03:35:14 AM »
OK, take a look at this:
The above picture works in conjunction with this:
It should be noted that I do not connect the wires directly to the points from the bottom of the board. What I do is locate the next closest hole and place the wires from the TOP of the board and then bend the bare wire to touch the points. Then I solder the wire to the point and to the pad/hole that it enters the bottom of the board from.
In other words, all my wires enter the board from the top, not the bottom.
Of course you need to strip the wire first using your wire stripper, then insert the bare wire into the board from the top.
aron
3: Build pictorial
« Reply #6 on: October 06, 2003, 03:51:23 AM »
Here's a picture from the DIY FAQ that shows a DPDT using the millenium bypass (LED circuit).
smoguzbenjamin
3: Build pictorial
« Reply #7 on: November 20, 2003, 01:35:43 PM »
??? With a DPDT switch, what do you connect to the 2nd pole? It's left open in your diagram...
aron
3: Build pictorial
« Reply #8 on: November 23, 2003, 12:41:10 AM »
You are right.
HMMMMM how long has it been like this?????
smoguzbenjamin
3: Build pictorial
« Reply #9 on: November 23, 2003, 05:45:36 AM »
I don't know, I only noticed it a week ago :)
gitrokr
SPST switch
« Reply #10 on: December 17, 2003, 12:03:47 AM »
can you show me how you would connect the ins and outs from the circuit board to a SPST switch to the in and out jacks please? thanks
aron
3: Build pictorial
« Reply #11 on: December 24, 2003, 04:21:49 PM »
For a SPDT, see the first picture of this link:
http://www.diystompboxes.com/pedals/articles/elbypass.html
Axmanjr
3: Build pictorial
« Reply #12 on: December 31, 2003, 10:08:07 PM »
:? I'm having a bit of trouble undertstanding where to hook up all of the wires after the components have been soldered.  I am trying to set up the board without a footswitch (so that I can just plug and play) and the one picture posted earlier isnt making any sense to me.  Where do I connect the negative terminal of the 9V battery snap?  Exactly where do I place the wirings on the input/output jacks? Also, do you have a pic of what the pot looks like with the cap on it?  Do you have an actual pic of the finished board with all the wirings, so that i can compare it to mine?  So many questions, but I'm just confused.  Thanks for any help.
smoguzbenjamin
3: Build pictorial
« Reply #13 on: January 01, 2004, 06:46:56 AM »
ryanscissorhands
3: Build pictorial
« Reply #14 on: April 10, 2004, 12:35:22 AM »
This is Pre-Newb calling. When/where did you solder the transistor in, and how can yu tell which lead is for which on a transistor? (SOOOO newb...)
pbsk8er03
3: Build pictorial
« Reply #15 on: May 10, 2004, 06:36:13 AM »
VERY very newb. Does it matter which holes u place everything on the circut board???If it does matter how do u  know??? :oops:  :oops:  :oops:
aron
3: Build pictorial
« Reply #16 on: May 10, 2004, 01:58:40 PM »
Good question, but remember this from the pictorial:
I keep chanting the golden rule:
If I connect the components together correctly, it will work. It doesn't matter if they are "in the air" or on cardboard, as long as they are connected together correctly (not shorting), the circuit will work.
So, start anywhere but connect the leads correctly and your circuit will work.
johnyze
Transistor?
« Reply #17 on: June 09, 2004, 07:20:37 PM »
Hey Aron, thanks for doing this fancy beginner's project, I've enjoyed attempting to work it out, and I am still working on it. But I noticed in your build picture, there is no actual transistor in the DIp8 socket. I was wondering why it's like that? Also, when I purchased my parts, being a newbie to the whole thing, the guy that I was talking to said I didn't need to bother with a ic socket thingy. Is that okay? or does that ruin the plan of the pedal? Thanks
John
aron
3: Build pictorial
« Reply #18 on: June 09, 2004, 07:53:04 PM »
You just push the transistor into the socket to place it in the circuit. Very easy.
The reason I used a socket is:
1: to tech you how to use/create sockets.
2: so you don't burn out the transistor from bad soldering.
3: So you can re-orient the transistor correctly if you placed it in the wrong way.
4: So you can try different transistors.
But yes, assuming your soldering is OK and you have the pins right, you don't need a socket. But it's fun to try different transistors.
rubberabbit
3: Build pictorial
« Reply #19 on: October 04, 2004, 03:43:11 AM »
uhm aron..half the pics on the page izzint loading...
