Strobe tuner
Started by nexekho, October 13, 2011, 11:34:10 AM
nexekho
Starting too many threads lately :p
Anyway, I'm going to be buying certain components in packs of 10 at Christmas because quite often a 10 pack is cheaper than 5-10 individual components and this means I have a LOT of 555s/comparitors/4017s left over.  I've noticed there are few if any tuner designs on here so I wanted to contribute something :p
There's only one bit I'm unsure on, the notch filter - I don't know if it'd be good enough or not without adding loads of active components.
The 555 feeds 10/20x the frequency you want into the 4017, which will power one LED at a time.  The signal goes through the notch filter to try and separate the strings.  (combined with the comparitor, probably good enough)  The comparator sees if the input wave is above/below a threshold and uses the MOSFET to block the ground for the LEDs. (probably want a resistor too - a 4017 gives out 5V logic level right?  Also probably a fine tuner fixed pot for the 555) If the frequencies match up, the resulting line of lit LEDs should be static, while a difference of even 1Hz will cause a very noticable slide to the left or right.
Falstad:
http://www.falstad.com/circuit/#%24+1+5.0E-6+38.696464541249114+50+5.0+50%0Aa+416+320+512+320+1+5.3+0.0+1000000.0%0AR+384+368+384+400+0+0+40.0+5.0+0.0+0.0+0.5%0Ag+448+416+448+448+0%0A174+448+368+384+336+0+1000.0+0.203+Resistance%0AR+416+304+384+304+0+1+441.0+2.0+2.65+0.0+0.5%0Af+512+320+560+320+0+1.5%0Aw+560+304+608+304+0%0A162+608+368+608+304+1+2.1024259+1.0+0.0+0.0%0A162+640+368+640+304+1+2.1024259+1.0+0.0+0.0%0Aw+608+304+640+304+0%0Aw+640+304+672+304+0%0A162+672+368+672+304+1+2.1024259+1.0+0.0+0.0%0A162+736+368+736+304+1+2.1024259+1.0+0.0+0.0%0Aw+704+304+736+304+0%0Aw+672+304+704+304+0%0A162+704+368+704+304+1+2.1024259+1.0+0.0+0.0%0A162+832+368+832+304+1+2.1024259+1.0+0.0+0.0%0Aw+800+304+832+304+0%0Aw+832+304+864+304+0%0A162+864+368+864+304+1+2.1024259+1.0+0.0+0.0%0A162+800+368+800+304+1+2.1024259+1.0+0.0+0.0%0Aw+768+304+800+304+0%0Aw+736+304+768+304+0%0A162+768+368+768+304+1+2.1024259+1.0+0.0+0.0%0A162+896+368+896+304+1+2.1024259+1.0+0.0+0.0%0Aw+864+304+896+304+0%0A163+576+400+656+400+0+10+0.0+5.0+0.0+0.0+0.0+0.0+0.0+0.0+0.0+0.0%0AL+896+464+944+464+0+1+false+5.0+0.0%0Ag+560+336+560+352+0%0AR+576+432+576+480+1+2+4400.0+2.5+2.5+0.0+0.5%0Ar+448+416+448+368+0+1000.0%0Ao+4+64+0+35+5.0+9.765625E-5+0+-1%0A
(NOTE: no input/output buffers, only one string, no tuner pot, 555 astable or LED resistor)
Is this how one would usually work if not done with a microcontroller?
I made the transistor angry.
greaser_au
Hi nexekho
This is a microcontroller version of a strobe tuner  (it's a 'pay to view' site, but if you click on the 'Fig.1' block diagram, you get a popup that allows you to view the images that accompany the article (the block diagram & the circuit are useful), which uses a very similar idea from a few years back. The microcontroller takes user input through the buttons (to select note & octave)  & generates the reference frequency for feeding to an octal counter which cycles through the anodes of a ring of LEDs.  The cathodes are fed by the (amplified) instrument signal.    http://www.siliconchip.com.au/cms/A_110736/article.html
Over 20 years ago Electronics Australia did the same thing with a top-octave generator chip feeding a 12-way switch (note selection), a binary counter/divider feeding a 6-way switch (octave selection) feeding a similar counter/LED ring (anodes) with the (amplified) instrument signal feeding the cathodes.
I built both kits over the years, and I've found these are excellent tools for doing guitar intonation (especially with the demise of tuners with analogue meters) - the drift of even very slight (fractions of Hz) frequency differences are quite obvious.
In both cases there isn't much in the way of filtering of the instrument signal - if anything I would use it to drive a one-shot, perhaps with a period suited to the octave in use! I intend to build a 32-led strobe tuner at some point, perhaps with auto note selection (I have to admit to being inspired by matzzz's design and 'the gimmick' for the autonote read).
david
nexekho
Cool stuff, cool stuff!  Thanks!
I have been playing around with passive filters in a simulator to try and roll off the signal to within 2-3 semitones of where each string should be so I can run six of the above and go polyphonic.  Not having much luck.  I like the idea of only having one though and a note/octave selector - I could use the signal generated (two of the 4017 outputs tied to a D type flip flop to divide the frequency by 10) with a transistor to modulate it with the signal to get some nice effects.  Also would allow for arbitrary tunings and use outside of guitars.
