Big Muff, Transistor question. (NYC EC-3003 Rev_C)
Started by stonerbox, November 24, 2011, 10:48:15 AM
stonerbox
I got a Big Muff Pi NYC (Blue board EC-3003 Rev_C) that I have installed lots of mods on.. Recently I managed to destroy Q3 Resistor (BC550) the ground lug snapped..  :icon_sad:
All I got at home for replacement are BC309, K118 Y7A, C3378 GR 7K, K184 GR 8A, K118 YL7 and A1048 GR 7K.
Could any one of these work? If I had time I would buy a new resistor but time is not on my side right now. Please help the newbie.
I'm sorry if i posted in the wrong section.
This is the circuit (Q3 "Q2" Second Clipping Stage):
There is nothing more to be said or to be done tonight, so hand me over my violin and let us try to forget for half an hour the miserable weather and the still more miserable ways of our fellowmen. - Holmes
frank_p
Hi Stoner, welcome to the forum,
I think the version of your box is the current reissue  ,if so, the schematic you posted is wrong polarity.
http://www.pisotones.com/BigMuffPi/psst/schm-black.jpeg
For starting BC309 is :
PNP  Hfe 120 to 800
http://pdf1.alldatasheet.com/datasheet-pdf/view/50725/FAIRCHILD/BC309.html
A1048
is 2sa1048 is pnp audio Hfe 70 to 400
http://pdf1.alldatasheet.com/datasheet-pdf/view/29939/TOSHIBA/2SA1048.html
K118 Y7A and
K118 YL7
is 2sk118  is a JFET  so NO
K184 GR 8A
is 2sk184  is also JFET so NO
I suspect that is the only one that will work:
2SC3378:   = YES   because NPN
Si NPN Lo-Pwr BJT
Various
npn transistors,transistors
V(BR)CEO (V)=20
V(BR)CBO (V)=20
I(C) Abs.(A) Collector Current=2.0
Absolute Max. Power Diss. (W)=400m
I(CBO) Max. (A)=100n
V(CE)sat Max.(V)=.3
@I(C) (A) (Test Condition)=10m
@I(B) (A) (Test Condition)=1.0m
h(FE) Min. Static Current Gain=200
h(FE) Max. Current gain.=700
@I(C) (A) (Test Condition)=2.0m
@V(CE) (V) (Test Condition)=6.0
f(T) Min. (Hz) Transition Freq=100M
@I(C) (A) (Test Condition)=1.0m
Package=SPAK
Military=N
stonerbox
Your right! Thanks for the reply frank_p. Very much appreciated!!  :icon_biggrin:
frank_p
stonerbox
Alright! now the pedal is in one piece again. Due to the poor quality of the EC3003C board I had to rewire the entire second clipping stage and the tone stage "outside" of the board. After a lot of hard work and tricky schematic reading (at least for a newbie like me) it is now functional again. Now with a 2SA1048 instead of the original BC550.
It sounds different now, lot less gaining going on, more of a fuzz/crunchy sound rather than the insane gain factor that was before. I barley use that much sustain, often around 10 o'clock. Now I get the 10 o'clock sustain sound at 3 o'clock. Go or bad? It all depends on the situation.
Thank you frank_p for the helping hand! Oh by the way, the schematic was not the right one, the EC-3003 Rev_C schematic seems to be nearly impossible to find out there.
DavenPaget
Quote from: stonerbox on November 25, 2011, 07:28:15 PM
I am not bothered to check the 2SA1048 but it smells like it's a much lower gain tranny compared to the 550 .
Hiatus
stonerbox
#6
I replaced the 2SA1048 first with a BC239... and then i added another BC309 on top of the BC239. Now it is starting to sound a lot better, more lows and more sustain/fuzz! I dig!  :D
frank_p
#7
Quote from: stonerbox on November 25, 2011, 08:39:25 PM
BC309 is pnp
Remove...
BC239 is npn OK
Quote from: DavenPaget on November 25, 2011, 08:07:49 PM
BC550 is npn
2sa1048 is pnp
http://html.alldatasheet.com/html-pdf/29939/TOSHIBA/2SA1048/246/1/2SA1048.html
2SC3378 and BC239 is the only parts in your lot that will work if I am not mistaken.  Because it's npn polarity like the BC550.
If you put a pnp there your sound will choke.
Blue board sound like npn polarity...  Scroll down:
http://www.kitrae.net/music/big_muff_history3.html
Can you measure some voltage with the multimeter ?
http://www.diystompboxes.com/smfforum/index.php?topic=29816.0
IF YOUR BOARD IS NPN (NEGATIVE GROUND), PUT YOUR PNP ASIDE.
You have a power jack plug at the back of the box ?  If yes: put all the pnp in your drawer: I wrote next to the numbers.
You can piggyback the npn ones as you want for your mods, the others: you will just probably damage them.
stonerbox
Quote from: frank_p on November 25, 2011, 09:20:21 PM
BC309 is pnp
Remove...
BC239 is npn OK
BC550 is npn
2sa1048 is pnp
You are right, the board has NPN Polarity, but I did not notice that the sound got "choked" by the BC309 C, rather a volume increase when I added it on top of the BC239 C. Strange..
One thing is for sure, they are a lot less gainy than the BC550 transistors. Maybe I should remove the BC309 C transistor, I would not want to risk damaging the other components.
Again, thanks for you support Frank.
frank_p
