What has the same pinout as the LM386 Op Amp?
Started by LucifersTrip, November 30, 2011, 07:44:26 PM
LucifersTrip
A friend has a pedal with a socketed, and now blown LM386. I rarely work with Op Amps but on a quick search, most I see have output at pin 5 (not pin 6 like the 386).
He complained about a fizzy decay, and I've also had similar problems in the rare instances when I used 386's.
Is there an alternative he can just snap in?  difference between LM386L and LM386N?
thanx
always think outside the box
CynicalMan
The LM386 isn't an op amp, it's a power amp. It's a different kind of chip, made to drive a low impedance load at a set range of gains. AFAIK there aren't any replacements or equivalents.
LucifersTrip
Sounds cool...Goes to show how little I use em! The 386's were in a sale list in the op-amp section...
Is there a difference between the L and N ?
thanx again
waltk
QuoteIs there a difference between the L and N ?
The LM386L is just UTC's version (L is for lead-free plating).  I've used both, and they are pretty much identical.  If you are replacing an LM386N-4, however, you might need to go with that as it allows a higher supply voltage.
LucifersTrip
Quote from: waltk on November 30, 2011, 08:42:38 PM
sounds good...His 386 is marked LM386L.
thanx much for the info....and back to the germaniums for me.
for the fizzle decay, stick a 100uf -220uf across the + -.....it worked for me! on the big bastard distortion... :)
LucifersTrip
Quote from: deadastronaut on December 01, 2011, 03:05:20 AM
thanx alot...I'll definitely try that.
I had the exact same fizzle decay problem with op amps (similar solution?). Again, I've made very few with IC's, but they stick in my mind. The worst was with a 4558 Muff Fuzz.
 it may work on other ic projects....i always have a 100uf on my breadboard just to filter psu...i think its pretty much standard practice going by a lot of schematics ive seen etc...
i know when i was experimenting with the 386 it was noisey as hell without a 100uf across the + -   hope it works for ya!.
Tylerdee
Excuse my ignorance as a novice but where would I place this cap in the circuit?
LucifersTrip
Quote from: Tylerdee on February 24, 2012, 07:26:52 AM
from the + of the power supply to the - of the power supply
I'm going to go out on a limb and suggest that, as far as use in pedal circuits goes, a 386 is a 386 is a 386.  If we were talking about running the chip as a small power amp into a low-impedance load like a speaker, then yes, power dissipation rating (what differentiates the 386-1 from the -2 and -4) would make a difference.  But for the small current-handling typical of distortions, I doubt that applies.
Electron Tornado
Quote from: Mark Hammer on February 24, 2012, 09:02:43 AM
Actually, I built an overdrive pedal with a 386. Started with a 386N-1 and the decay was fizzy. Replaced it with a 386N-3 and the decay is smooth with no fizz.
"Corn meal, gun powder, ham hocks, and guitar strings"
Who is John Galt?
So then, it is essentially the same relationship as changing one's dual op-amp in a TS build.  In other words, the tone may change in a preferred or nonpreferred direction, but the circuit will still "work" without risk to components.
Perrow
And make sure you're not stuck with a dead or dying battery. Tested a Ruby (386 amp) with the power supply current limit turned way down and it wasn't beautiful. Turn it up and everything was OK.
LucifersTrip
#14
I forgot to reply...
I did eventual try the LM386N-1 to replace the LM386L, hoping it might remove some fizz....and it was a complete flop.  It was completely different  than the LM386L, only giving me a mild, muddy distortion instead of the fuzz I already had....very surprising.
In the end, a relatively small cap (3.3uF) across the power supply completely solved the fizz problem.
