Pages: [1]
Author
Topic: Which one is the gain resistor ? (Read 996 times)
DavenPaget
Dave.S / Dave Seether
 Found this schem of my pre-fabbed "tone control" ( actually i redrawn it ) I'm confused . OH wait , R12 resistor has been swapped for 1M .
Logged
Hiatus
TimWaldvogel
i know this probably irrelevant but couldnt you just change the op amp stage to a non inverting setting with a fixed gain of maybe 5-10 to make up for the insertion loss of the tone stack.
and out of curiostiy, cause i AM NOT an expert. but does the 10uf decoupling need to be there after the transistor, before the tone control?
Logged
YOU KNOW WHAT THEY SAY ABOUT LARGE PEDALBOARDS....
.... I BET YOU WISH YOUR PEDALBOARD WAS AS LARGE AS MINE
DavenPaget
I don't know ... it's not my schematic ...
Logged
Hiatus
TimWaldvogel
and i believe R9 the bias resistor for the circuit so i believe by putting a pot in it place would control the bias of the transistor giving it more output? i honestly dont know, i am new to transistor circuits, i am more of an op amp guy lol
Logged
TimWaldvogel
[/quote] I don't know ... it's not my schematic ... [/quote]
gotcha ! i believe this circuit was meant to buffer the signal to a low impedance source so the tone stack would react properly and the op amp may give a tiny bump up from the tone insertion loss
Logged
DavenPaget
According to TI , it is a non-inverting setup . The paper in which i copied the schem from said -2db loss .
Logged
Hiatus
Gurner
It's inverting....T1 doesn't invert, the TL072 does (it's non inverting input is being held to 1/2 VCC & the signal goes in on the inverting input), therefore a non inverting stage followed by an inverting stage = inverting. The bass & treble pots ultimately set the (fequency based) gain ...the gain will dependent on the position of the wiper (think of them as two separate resistors as you'd see in a standard inverting opamp config the wiper being the junction)
« Last Edit: December 04, 2011, 01:05:24 PM by Gurner »
Logged
DavenPaget
i was referring to texas instruments .. then i checked it again , it is indeed held to 1/2 VCC ... any way to set gain ? This is already prefabbed therefore i have no choice .
« Last Edit: December 04, 2011, 01:01:35 PM by DavenPaget »
Logged
Hiatus
Keppy
There's no voltage gain on a transistor emitter follower, so that leaves the opamp for gain. The gain of an inverting opamp stage is 1 + (Rfeedback/Rinput) (I think). That means the gain is set by the complex resistance networks in the tone stack and varies by frequency. That would take some working out to determine what the gain is, but I think you can adjust it by sticking a pot in the feedback line from the opamp output to the tonestack. Use lugs 1&2 to set up a variable resistor and see what happens. Start with a 100k pot.
Disclaimer: I have not tried this before, so this is purely theoretical advice. Worth a try though, I think.
Logged
DavenPaget
Alright ! Will try it soon .
Logged
Hiatus
Gurner
the way to increase the gain - as with any inverting opamp - is to allow less of the opamp's output signal to be 'fed back' to the opamp's inverting pin. When you feedback 100% of the signal you get a gain of 1 from the opamp, when you feedback none of the output signal you get a gain of ininfity - normally a voltage divider chain is utilised to set the gain somewhere in between ...therefore if you want more gain, I'd say put a resistor between the opamp pin 6 & R7....as a finger in the air, I'd say something like 47k to start with.
« Last Edit: December 04, 2011, 01:10:59 PM by Gurner »
Logged
DavenPaget
the way to increase the gain - as with any inverting opamp - is to allow less of the opamp's output signal to be 'fed back' to the opamp's inverting pin. When you feedback 100% of the signal you get a gain of 1 from the opamp, when you feedback none of the output signal you get a gain of ininfity - normally a voltage divider chain is utilised to set the gain somewhere in between ...therefore if you want more gain, I'd say put a resistor between the opamp pin 6 & R7....as a finger in the air, I'd say something like 47k to start with. I placed the wrong opamp there ... supposed to be TL081 . so it should be 2 and R7
Logged
Hiatus
arawn
It's a 2 knob eq with boost or cut, in order to affect the overall gain of the circuit you have to add another amplification stage after the tlo72. the gain of the 072 is being controlled by the bass and treble pots and is frequency dependent. if you mess with the gain control on th 072 you will lose your eq capability and end up with a bog standard gain stage or woirse one that doesn't work correctly.
Logged
"Consistency is the Hobgoblin of Small Minds!"
Gus Smalley clean boost, Whisker biscuit, Professor Tweed, Ruby w/bassman Mods, Dan Armstrong Orange Squeezer, Zvex SHO, ROG Mayqueen, Fetzer Valve, ROG UNO, LPB1, Blue Magic
DavenPaget
Oh crap ... Looks like i'll have to use this tone control for another purpose ... and build a FMV stack  ( anyone has any good FMV preamps with distortion schems that i can use ? )
« Last Edit: December 04, 2011, 01:25:32 PM by DavenPaget »
Logged
Hiatus
WGTP
Have your tried the STM version?
Logged
Stomping Out Sparks & Flames
DavenPaget
Have your tried the STM version?  What where ?
Logged
Hiatus
WGTP
Logged
more
Yes to several of the comments.
- it's inverting at mid band where the frequency rolloffs don't mess with phase. - the tone pots are an active Baxandall circuit. This has a nominal gain of 1 when controls are flat - you can't goose up the overall gain (at least not easily and well) with the only opamp that's there
The simplest way to get a tone control with gain is to add another opamp stage before or after. Or to convert the input emitter follower to a gain stage. That partially poisons its ability to drive with low impedance, but maybe something could be worked out.
Be careful what you ask for. These things have an active boost when turned to the boost positions on the bass and treble pots. 12-15db is common (I haven't looked at this one in detail to see what the max boost is). If you add another gain stage, it's easy to get so much gain that you run out of power supply room on the output of the opamp unless you then go to bigger power supplies.
Logged
What *was* the media thinking? Did they really believe that only the Second Amendment would be suppressed for political convenience? There are all those other pesky limitations on power to be dealt with, too.
DavenPaget
Thanks RG but i the entire circuit can run on 15v and this was connected to a 15VDC regulator until i removed it yesterday night ... I just checked . 15db bass and treble gain .  I believe R6 can be subbed for a 50k VR right ?
Logged
Hiatus
Paul R. - Maine USA
Logged
Pages: [1]
