Stereo A/B Switch for Expression pedal
Started by matthudson00, December 22, 2011, 01:28:24 AM
matthudson00
I have 2 effect pedals that I want to control with one expression pedal. My idea is to make a simple A/B pedal so I can select which effect unit I am controlling with the expression pedal. I've never made something like this but I am very familiar with soldering and other DIY projects.  The plug on the expression pedal is a TRS plug and I'm having difficulty figuring out how to wire a TRS A/B box. I'm also interested in wiring two LEDs into the box so that I know which channel I am using. Any information would be very helpful. Thanks a lot!
-Matt
Sam i am
hey Matt
I'm a complete newbie to all this electronics and effects but i was looking through some switch stuff a while ago and i think i may have found an answer but I'm probably wrong because i have no idea how it would hook p to an expression pedal but its worth a look:
http://www.beavisaudio.com/projects/ABSwitches/
Sam
matthudson00
Yeah I found that link too but I don't think it's exactly what I am looking for. Anyone else?
CurtisWCole
If both pedals require a stereo jack and a two conductor cable then you could use a 4PDT switch. I'd also use two stereo plastic jacks in case of ground loop issues.
http://www.smallbearelec.com/Detail.bok?no=1073
http://www.mammothelectronics.com/4SFS4PDT-LS-p/800-1004.htm
Wire it up like this.
FX1 Tip   FX1 Ring   FX1 Sleeve    LED1
EXP Tip   EXP Ring   EXP Sleeve    GND
FX2 Tip   FX2 Ring   FX2 Sleeve   LED2
This won't ensure silent switching, but should get the job done.
Curtis
Composers shouldn't think too much - it interferes with their plagiarism.
Howard Dietz
CurtisWCole
Howard Dietz
matthudson00
Perfect! Thanks a lot! I'll report back when it's done.
