Steve Morse delayed (?) reverb effect
Started by StephenGiles, December 23, 2011, 04:07:38 PM
StephenGiles
I've been listening to Steve's guitar antics, and one of his tricks seems to involve reverb braking in during a single sustained note after a fast run. So could that be a CV extracted from the decay of the single note which is applied to a VCA controlling the reverb output perhaps? Or it could just be a volume pedal :icon_question: :icon_question:
It could also be a pluck follower in reverse, ie the slower you play, the higher the CV - any thoughts?
deepMago!
I've seen time ago a video showing Morse's rig time ago. He uses volume pedals before the effects and simply open them to add effects. No switch system, only a volume for delay, one for reverb and one for gain level if I remember well. One amp for dry signal and one for effects.
StephenGiles
Thanks - he's up there with the likes of Jeff Beck to my ears!!
pinkjimiphoton
when i met hom last year, he was using two half stacks, and a tc nova delay in stereo with volume pedals. to get the effect, he'd just swell into the echo, coming from the second amp.
Slava Ukraini!
~Jack Darr
StephenGiles
pinkjimiphoton
beats me. he just turns up the volume pedal feeding the input of the echo with a lotta repeats.
Slava Ukraini!
~Jack Darr
Taylor
Many commercial delays/reverbs have the "ducking" feature, which is where the dynamic envelope controls either feedback or effect mix. If you wanted to build it, it would just be a matter of taking the envelope section from an optical compressor and putting the optocoupler in parallel with a delay feedback or level control.
oliphaunt
A ducking delay or reverb is my suggestion also.
StephenGiles
Yes but how would you configure a "slow playing detector"? Fast flurries of notes - no reverb, single sustained notes - plenty of reverb, echo or whatever. That would be the clever bit!
Taylor
Unless you play with a heavily compressed signal, IME just heavier filtering on the rectified signal creating the envelope will do it, since a bunch of note attacks will average to a higher DC level than a sustaining note tail. I have done this digitally, but the concept is the same in analog.
  It'd seem pretty easy to do by throwing Photocells in the mix section, once the envelope detector to brighten LED's, and reverse the LED brightening to dimming effect by using a transistor inverter, to dim any LED's where you want inverted signal-to-LDR effect...  's figured out...
  Then just use LDR's to attenuate the reverb tank signal output, perhaps boost the clean mix [using LDR's to control gain] to fill in the loss [or more].
   Use light blockers or switch to do the sweeping honors, [and/or] trim LDR's with R's as needed.
