Guvnor PCB Layout
Started by Perkla, January 06, 2012, 05:06:08 PM
Perkla
I have been thinking if there is anyone that have a different PCB layout for the Guvnor than the one that is avalible on GGG ? I would like to have a better clean look of the PCB and better organized as well.. anyone know anything about it ?
Perkla
Maybe i have to create my own PCB layout.. :D
Ice-9
I made one quite a while ago, but it has the jacks and 3pdt all on the pcb, maybe if you wanted to use it you could alter it and remove the jacks and bypass footswitch.
www.stanleyfx.co.uk
Perkla
Sure.. i would like to have a look at the both verisons.. :D  would be cool to see :D
J0K3RX
Perkla
Quote from: J0K3RX on January 06, 2012, 08:21:26 PM
http://www.tonepad.com/getFile.asp?id=108
Yes i have seen that one.. but it does not have a clipping switch and i dont like that. Clipping is good i think.. i like it alot.
J0K3RX
#6
If you are wanting to create your own board layout you can very easily add a clipping switch to that layout... if you use a rotary switch you could choose from many different clipping options and just leave out D1 and D2 and attach it to the two pads for D2... You could have possibly 10 different clipping options using different diode combinations...
Perkla
Thats cool.. but i only would like to have one clipping switch, i am not very good at schematics and stuff like that so.. i dont know where to put the clipping option on the tonepad Guvnor PCB layout.
arma61
Hi
I should have a PCB, based on Tonepad layout, with clipping switch "on board", it's quite "raw" but IIRC it's working, it should be about 8x5cm, let'e me dig it out form the HD and I'll post it in a while.
Ciao
Armando
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
Perkla
Quote from: arma61 on January 07, 2012, 09:35:02 AM
Hi
Ciao
Armando
That would be awesome.. :D
arma61
here you go!
as I said before a little bit raw, but verified and working ;)
http://www.aronnelson.com/gallery/main.php/v/diyuser/Arma61/Marshall+Guvnor+D_pcb.html
http://www.aronnelson.com/gallery/main.php/v/diyuser/Arma61/Marshall+Guvnor+D_sch.html
those are ExpressPCB and ExpressSCH files you can download and work on them to modify to your needs.
Ciao
Perkla
Quote from: arma61 on January 07, 2012, 11:30:26 AM
here you go!
Ciao
Thanx.. but i cant open those files in Express PCB... :S  i use "Open" and the program does not find the .pcb files... maybe its not .pcb files ?
arma61
you need to click on the above link then, on the new page, you click on "Download file, then you can open them, if you, as I suppose, just right click and save on above link I think you save the html code ;)
let me know.
Ciao
Perkla
Quote from: arma61 on January 07, 2012, 12:00:32 PM
let me know.
Ciao
Yes i clicked on the link and then on "Download File" and saved it to my computer.. but no i cant open it.. are u sure its the program Express PCB and not PCB Express ?
arma61
sure it's ExpressPCB and ExpressSCH files !  ;)
probably they've been saved like this
Marshall Guvnor D_pcb
Marshall Guvnor D_sch
try to save them with a dot instead of the underscore sign or..send me a PM with your email and I'll send them to you privately.
Perkla
Yes.. i renamed the files with a dot and it seems to work now.. :D
Perkla
Quote from: arma61 on January 07, 2012, 12:35:33 PM
Do u have a wire diagram for this PCB layout ?  Pretty cool with the clipping option as well :D  must be possible to wire this so that all 4 diodes can be used at the same time ? that will give more gain ?
Perkla
Quote from: Perkla on January 07, 2012, 12:42:29 PM
A partslist would be cool to.. :D
J0K3RX
Perkla - You can copy the BOM from the schematic... In case you don't know how here it is for you. :icon_wink:
C1   0,1uF
C2   120pF
C3   0.068uF
C5   0,01uF
C6   0.068uF
C7   10uF
C8   220pF
C9   0.22uF
C10   0.1uF
C11   0.22uF
C12   0.01uF
C13   0.004uF
C14   470pF
D1   Red LED
D2   Red LED
D3   1N914
D4   1N914
DPDT1
R1   2.2k
R2   10k
R3   1M
R4   47k
R5   47k
R6   680k
R7   1k
R8   680R
R9   1.5k
R10   680R
R11   100R
R12   22K
R13   100
R16   2M2
U1   TL072
Perkla
Thanx ALOT... very good ppl u are .. very helpfull for me and others.. :D
I was thinking if the pads on the PCB layout are to smal to be able to solder ? i tested to print the PCB layout and they are really smal.. maybe will work.. ?
