|AMPAGE| |GEOFEX| |AMZ|
May 25, 2013, 04:15:34 PM
892017 Posts in 97650 Topics by 28717 Members
Latest Member: JackOfBlades
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  Sound 2 Light with LM386N-3? 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: [1] Go Down Print
Author Topic: Sound 2 Light with LM386N-3?  (Read 652 times)
bluesdevil
Just a Bill in Florida
« on: February 14, 2012, 08:25:45 PM »
I'm trying to get the "Sound 2 Light" circuit to work as a gate for my Anderton Ring Modulator build, but the LED stays on whether the input of the op amp is connected or not. I'm using a LM386n-3 instead of the LM386n-1 that's noted here:
http://www.aronnelson.com/gallery/main.php/v/chickpea/sound2light_.jpg.html
http://www.diystompboxes.com/smfforum/index.php?topic=82843.0
Could that be the problem? Also gets VERY hot.
Can't believe I'm muffing up such a simple circuit!
« Last Edit: February 14, 2012, 08:30:55 PM by bluesdevil » Logged
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
Rob H. LONDON
WWW
Re: Sound 2 Light with LM386N-3?
« Reply #1 on: February 15, 2012, 02:55:08 AM »
hmmmm never used a -3  only a lm386n-1...
hold on ill bread it and see where it might be going moody...
ok, here goes, use input pin 3 (sorry wrong input on the diagram Roll Eyes) ,  and use 2 superbright 5mm blues in series, and a 470r-1k(adjust resistor value to taste/response) to ground, ...it wont go off/on with just 1 led...
its working fine on my breadboard.with lm386n-1.. Wink let us know how you get on...
i'll try it with a lm386n-3 and see if it gets hot... Wink
note the thread version is input 3....
« Last Edit: February 15, 2012, 03:13:51 AM by deadastronaut » Logged
bluesdevil
« Reply #2 on: February 15, 2012, 03:57:39 AM »
Thanks for replying, Rob. You are right, it doesn't work with just one LED..... 2 in series did the trick and no heating up of the 386n-3!!!
Now on to try it with a LDR to see if I can make some of gate with it. Really cool circuit, thanks for sharing it! icon_twisted
Logged
Rob H. LONDON
WWW
« Reply #3 on: February 15, 2012, 04:20:13 AM »
cool, glad you got it going man!... Wink
Logged
Gurner
« Reply #4 on: February 15, 2012, 05:19:43 AM »
Just be warned - gate circuits normally need a degree of precision - & the led brightness as driven by the Lm386 will fade along with battery voltage, unless you regulate the supply to the Lm386, you'll end up with a different 'gate' point as the battery afeds.
Logged
bluesdevil
« Reply #5 on: February 15, 2012, 02:29:16 PM »
No battery used, just an adapter for power, so hopefully that will help get it tuned in.... haven't had time to hook it all up yet, but soon!
***UPDATE***
Okay, it worked, but the decay ended up being a bit quicker than I wanted so I may just go with a separate noise gate pedal after it to squelch the carrier feedback.
I found a post with Mark Hammer suggesting to use the envelope follower in Dr. Q to do what I wanted to do with the LED/LDR combo, but I'm not quite sophisticated enough to figure it out.
« Last Edit: February 15, 2012, 08:34:19 PM by bluesdevil » Logged
artifus
dare to be naïve
« Reply #6 on: February 16, 2012, 01:18:08 PM »
have you tried a large parallel capacitor across the leds? series cap may soften the attack too.
Logged
bluesdevil
« Reply #7 on: February 16, 2012, 09:04:21 PM »
Thanks Artifus for your reply. I tried a cap across LED's, but they would not light with it.
Before boxing up I might try the Mark Hammer fix by using Dr. Q envelope follower circuit fragment.... if I can figure it out.
Logged
Pages: [1] Go Up Print
« previous next »
Jump to:
