|AMPAGE| |GEOFEX| |AMZ|
May 25, 2013, 12:08:21 PM
891985 Posts in 97647 Topics by 28717 Members
Latest Member: JackOfBlades
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  Zvex Super hard on clone. 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: [1] Go Down Print
Author Topic: Zvex Super hard on clone.  (Read 2490 times)
vince37
« on: February 24, 2012, 05:47:52 PM »
Hi,
I've built a SHO clone.... All works and sounds nice but I get a significant volume boost at minimal settings? (no unity gain) just wondering if thats normal or if I've thrown a wrong component in there somewhere?
Cheers
Logged
LucifersTrip
^^ Fuzz Skull ^^
WWW
Re: Zvex Super hard on clone.
« Reply #1 on: February 24, 2012, 05:52:26 PM »
Hi,
Cheers
it brightens up the tone at low setting, which you might consider a boost...watch a couple youtube vids for an idea
Logged
always think outside the box
vince37
« Reply #2 on: February 24, 2012, 05:55:33 PM »
I've watched a few demo's, It might just be my ears... It does brighten the tone but I get a big volume jump too..maybe just the way it's meant to be...
Thanks for the reply Smiley
Logged
phector2004
Phil T.
« Reply #3 on: February 24, 2012, 06:14:42 PM »
Nope!
Mine's almost unity at low settings...
Then again, how do we know I haven't botched mineGrin
Logged
LucifersTrip
^^ Fuzz Skull ^^
WWW
« Reply #4 on: February 24, 2012, 07:03:42 PM »
Nope!
by checking who has closer to the proper voltages
Logged
vince37
« Reply #5 on: February 25, 2012, 02:22:56 AM »
Sounds like mines the 'botched' one Sad ..... Google says that some people can even go below unity gain etc so now it's just working out what the hell I've done.
Logged
runmikeyrun
Mike T. Akron, OH
« Reply #6 on: February 25, 2012, 03:59:26 PM »
did you wire in a volume pot?  That will solve your problem, if it's working fine but just too loud then turn it down.  you could even just use a trim pot inside, set it, and forget it.
Logged
I know what a wipe knot is!!!  Isn't that something you end up having to do after bad Mexican?  -ayayay!
Stay Asleep- a dysfunctional marriage of hardcore, metal, and rock and roll.  Find us on facebook.
vince37
« Reply #7 on: February 25, 2012, 04:05:41 PM »
Sounds interesting, but as I'm new to this that all just went over my head... I'll have to go read up on that
Thanks Wink
Logged
phector2004
Phil T.
« Reply #8 on: February 25, 2012, 04:28:52 PM »
Just out of curiosity, what schematic/layout are you using?
I think I've seen 2-3 variants of this circuit...
Logged
LucifersTrip
^^ Fuzz Skull ^^
WWW
« Reply #9 on: February 25, 2012, 04:40:31 PM »
Thanks Wink
look at a schematic for another volume pot and just copy it. most are the same. the only thing you have to experiment with is the size.
look at the one on the Fuzz Face
now look at the SHO (thanx analogguru):
...so, copying it, center lug of vol pot goes to output, lug 1 goes to ground and lug 3 goes to 100K/10u junction
good luck
Logged
vince37
« Reply #10 on: February 25, 2012, 04:41:25 PM »
I used this one... It was the first one I came across
http://melxfx.blogspot.com/2010/07/big-fat-pink-boost-part-two.html
Logged
vince37
« Reply #11 on: February 25, 2012, 04:43:53 PM »
Thanks for that! I'll have a look into that.
Logged
vince37
« Reply #12 on: February 25, 2012, 04:45:25 PM »
Sorry quoted wrong comment....
Was meant for 'Fuzzy skull'
Cheers, I'll look into it Wink
Logged
Rob H. LONDON
WWW
« Reply #13 on: February 26, 2012, 05:34:25 AM »
i'd go with what runmikey suggested,
stick a trim pot on the output wire before it goes to you output/3pdt switch, this way you can set it to unity (matched to bypass) , then forget about it..
ive had to do this on a few builds myself......
so...  output wire from pcb> lug 3 of  100k trim pot then a wire from lug 2 of trimpot to your 3pdt switch.....turn till you get unity...sorted!.. Wink
Logged
MichelP
« Reply #14 on: February 26, 2012, 07:52:23 AM »
'I've built a SHO clone.... All works and sounds nice but I get a significant volume boost at minimal settings? (no unity gain) just wondering if thats normal or if I've thrown a wrong component in there somewhere? '
I had the same problem with my DIY SHO.  I had used for R3 a 51 K resistor instead of 5K1. When I changed it unity at minimum setting.
Logged
vince37
« Reply #15 on: February 26, 2012, 09:09:18 AM »
Really, I'll have a look at my resistors and double check and if not, I think maybe a trim pot might be an answer... just bugs me that something must be wrong somewhere... I have OCD (not the pedal) like that l0l ;-)
Thanks...
Logged
pinkjimiphoton
"it's got YOY" jimi in manchvegas
WWW
« Reply #16 on: February 26, 2012, 12:23:38 PM »
i've built 4 of them, all with bone-stock components and the usual 1% metal film resistors...
and every one gives AT LEAST a 6DB boost when engaged..probably twice that, to the point where i added master volumes to the ones i use live.
Logged
i don't care what ohms law is, i ain't no flippin EE!!
vince37
« Reply #17 on: February 26, 2012, 01:46:02 PM »
Well reading about them, it does say they can react differently with guitar/amp combinations. I've built two now with the same results so I'm just going to throw a trim pot in and be done with it Smiley
Logged
LucifersTrip
^^ Fuzz Skull ^^
WWW
« Reply #18 on: February 26, 2012, 05:42:19 PM »
just checked mine and it is almost perfectly at unity at lowest setting with neck pickup...with more brightness, of course.
Logged
LucifersTrip
^^ Fuzz Skull ^^
WWW
« Reply #19 on: February 28, 2012, 10:27:36 PM »
here are the voltages on mine:
           G      D      S
min   2.81, 7.36, 2.48
max  1.49,  2.98,  .13
Logged
Pages: [1] Go Up Print
« previous next »
Jump to:
