Pages: [1]
Author
Topic: Spring reverb tank (Read 1730 times)
While Rod Eliot is a thoughtful designer (and patient exlainer), the voltages required may be considered - while not exactly overkill - furnishing "comfortable" margins of error. Perfectly acceptable spring reverb systems can be made using a simple single-ended 12vdc supply. The key thing to remember is that the input transducer on the tank is essentially a low-efficiency speaker, so it needs a reasonable current to drive it. This is why such circuits invariably use either a 386 (made to drive headphones and small speakers), or an LM833 or NE5532 dual op-amp (both made to handle low-impedance loads...like headphones or speakers). By "reasonable current", I don't mean an amp or two, but I do mean something more robust than a 9v battery or a 6-pack of AA cells.
Something running off a 12v/500ma supply should be more than sufficient to do the job.
Logged
JonasL
Allright, and any idea about the diodes?
Logged
None. And when I note that a decent reverb system can be had with a 12v single-ended supply, I do not mean that you can simply apply +12v to Rod's circuits and they will work. I mean that there are other decent reverb circuits out there that will run well off +12v.
Logged
Yes, but you will want to change chips. To the best of my knowledge, while the 4136 has decent noise specs (or at least what was considered decent for the time - circa 1980), it is not optimized to feed low-impedance loads.
You are recommended to go with either a pair of LM833 or NE5532 dual op-amp chips, or an LM837 quad op-amp chip (a pair of LM833s on a 14-pin dip). Note that you will not be able to use any existing board layout intended for the 4136, although perfing this to accommodate a chip-change won't be especially difficult..
Logged
And DO NOT drive yourself crazy looking for 39uf caps, for heaven's sake. A pair of 47Uf or 100uf caps will do just fine.
Logged
JonasL
Okay thanx, i'll keep that in mind. And i think i will use the LM837, that seems the easiest way to me.
Logged
joelindsey
The other day I built a reverb unit mostly following the schematics on the first link posted, ( http://sound.westhost.com/project34.htm) except I adapted it for use with a single ended supply. If I recall correctly I put another 100k resistor on the non-inverting input going to +9v, making the voltage at that point 4.5v. I also got rid of the mixing section, as I don't intend to use it as a stompbox in my pedal chain. It would sound very good, except it's terribly noisy with a great deal of hum. I suspect it is coming from the recovery section because adjusting the drive control for the lm386 does not affect the noise. Does anyone have any experience in this regard? The changes I made to the circuit in the link above were changes that I thought would work, not changes I knew would work. Didn't turn out so good.
« Last Edit: February 29, 2012, 09:00:36 PM by joelindsey »
Logged
JonasL
I guess this must sound stupid, but i'm not an electronics expert... Can I just use the LM837 instead of the 4136 (keeping in mind the different pinouts), or do i also need to chance the values of other components?
Logged
No it's a fair question. Just think of it like switching from a stubby screwdriver to a long-handled one. Same screws, same project, easier turning.
Pay attention to the pinouts, but everything else is fine. I've posted a number of potential mods to the circuit which are searchable here, probably under "Stage Center reverb". They're not compulsory make-or-break, just improvements to find the tone you want. Other folks have posted them too, and there may even be some build comments over at GGG that can help out.
Logged
Paul R. - Maine USA
> drive circuits needs 35V en the recovery circuit needs 15V
Recovery is shown with +/-15V; 30V split in half either side of ground. Likewise the Fig 6 plan uses +/-35V (70V total) which is WAY over the top.
> this tank has a DC resistance of 200 Ohm, which makes it more complicated.
No. Use the Fig 5 circuit, it will be ample. In fact you can omit the D1 D2 R3 R4 Q1 Q2 R5 R6 buffer: '5532 has plenty of current to slam a 200DCR 1.5K nominal tank.
Millions of good guitar-amps use a single chip at +/-15V to drive nominal 1.5K (200DCR) tanks.
FWIW: the diodes may as well be 1N4007. Or 1N4001; but same-price in DIY and the '07 can be used many more places. You may also use 1N914 1N4842(??) small-signal diodes; but without heavy analysis the large-signal diodes are less likely to over-hot-bias the transistors. But you do not need the transistors (or diodes) to slam a 1.5K tank.
> Will this circuit work with
It's a pretty 1976 plan. Simple. Not fully optimized. The recovery amp is not as low-noise as it could be. The drive gain is high and not adjustable. It "booooings"; but if you turn it to "surf rock" it will be a bit harsh then pushed hard, and will hiss if you ever stop.
'4146 is now a collector's item. It _will_ drive 2K (and 1.5K) decently, as good as TL072 which is common in commercial amps with similar tanks. But unless you "must" use that PCB (laid out for 4146) you want to pin-out for TL072, TL074, some 5532, etc. LM837 is also a good chip, though un-fashionable for no good reason. (It attempted to ape the '5532 but as a Quad; layout is often easier with Duals and the 5532 was a known-good multi-source chip while the LM837 was single-source newbie.)
Also note the TWO 9V batteries. It runs +/-9V.
And unless that tank is exceptionally low-price for you, I'd really favor the "standard" tanks used in 95% of all 'verbbed guitar amps since the 1960s. Every few years someone produced a "non-standard" to shave a few bucks; few of these ever caught on. This crate of tanks seems to have been un-loved since the 1980s; I wonder why.
« Last Edit: March 02, 2012, 05:29:25 PM by PRR »
Logged
JonasL
Could you explain me what the -15v is and how i must use it? I've never worked with negative voltages before.
Logged
artifus
dare to be naïve
 *edit* in my (admittedly limited) understanding it's very much like biasing an op amp with a resistor divider network but with a more reliable reference voltage - 0v. hopefully someone more knowledgeable than myself will chime in and correct me if i'm wrong.
« Last Edit: March 06, 2012, 02:57:32 PM by artifus »
Logged
JonasL
When i leave the buffer, then to where go pin 8, 4 and 1 of the 5532?
Logged
Pages: [1]
