4066 Bypass popping resolved
Started by electrosonic, March 03, 2012, 12:14:00 PM
electrosonic
It took a couple of days of reading and bench time but I finally made my 4066 bypass pop free. I thought I would post this for anyone else who might be having problems.
Things I figured out.
1) If you try to measure a bias voltage that is fed with a high value resistor your DMM will probably load the circuit give you an incorrect reading. If I have a 1 M resistor to the 1/2 V+ point and try to measure that with a DMM with a input impedance of 10 M,  the loading is significant in this case. The voltages I was looking at were in the millivolt range, so it makes more sense to measure the voltage across the switching element, not with respect to ground.
2) The inputs and outputs need to be biased to 1/2 V+
3) The resistors used to bias the inputs and outputs can't be too large. I had 1 M resistors in there and the switch popped, lowering them to 100k got rid of the pop. Something to do with internal capacitance of the IC, explained by RG elsewhere (something about charge injection). I have built a 4053 bypass with 1 M bias resistors and it didn't pop, not sure it you need to check this on a case to case basis.  (I just noticed on page 103 of "The Stompbox Cookbook" there is circuit snipped of a 4066 switch with 10k bias resistors)
4) After that I still had a slight pop, and I measured 22mV across a switch element. I finally figured out that 220 nA was flowing through a 100k resistor to product that voltage. It was the bias current for the NE5532 that I had put after the 4066. I replaced that with a TL072 and the noise is gone.
Nothing original here,  I must have read all these points ten times elsewhere before they sunk in.
Andrew.
mmaatt25
Hi
I've been messing around with 4066's I've not suffered from popping but have had problems with crosstalk.
Have you got a schematic?
Cheers
Matt
electrosonic
I posted the schematic in a different thread...
http://www.diystompboxes.com/smfforum/index.php?topic=96246.0
I ended up changing the output stage, because I hate to waste 1/2 an op amp. (Not that there is any logic to that, given how cheap they are).
I previously built a similar bypass board with a 4053 fed by a TL072 buffer, the other 1/2 of the TL702 was for a buffered bias voltage, which works fine.
Andrew.
electrosonic
PS. Your schematic looks very similar to this one...
http://members.shaw.ca/roma/switching-2.html
Minus the disembodied head...
Andrew.
mmaatt25
Quote from: electrosonic on March 04, 2012, 10:36:02 PM
Andrew.
Yeah thats where I started, but as I wanted three outputs I had to add/change a few bits.
Please note I dont take any credit for the circuit. That said I dont recall a patent for an LED, a resistor and a 9v battery  :icon_wink:
Have you had any issue with cross talk??
electrosonic
I haven't had a problem with crosstalk, I mute input to the effect when it is bypassed to minimize that. The visual sound jekyll and hyde schematic I have seen on the web does not mute the input to the unused effect (it is two distortion effects in one box) so it probably is not strictly necessary.
Andrew.
