|AMPAGE| |GEOFEX| |AMZ|
May 20, 2013, 01:39:50 AM
890820 Posts in 97550 Topics by 28670 Members
Latest Member: Sonicdeath
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  EP Booster Clone in a VP Jr. 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: [1] Go Down Print
Author Topic: EP Booster Clone in a VP Jr.  (Read 880 times)
spfautz
« on: March 03, 2012, 10:25:11 PM »
I'm thinking about using the big empty cavity in my EB VP Jr. to hold my EP booster clone.  My idea would be to drill a couple of holes in the side for the power, pot, in and out.  Since I'm thinking about using it in a more always on pre amp type of way, I was thinking of a 3pdt toggle instead of a footswitch (its also coming out of the side which would be weird for footswitching).  Does this seem like a good idea?  Am I not considering something I should be?
Thanks,
Stefan
Logged
mremic01
Re: EP Booster Clone in a VP Jr.
« Reply #1 on: March 03, 2012, 10:52:17 PM »
I don't see why that wouldn't work. If you've never worked inside of a tube amp before, just remember to read up on how to discharge the filter caps. Those can hold a charge and kill you even when the amp isn't plugged in.
Logged
spfautz
« Reply #2 on: March 03, 2012, 10:53:53 PM »
Tube amp?  I'm talking about my Ernie Ball Volume Pedal Jr.  Thanks for the concern.  For the most part I can't die from the volume pedal right?
Logged
blackcorvo
Lucas, Guitarrist wannabe, Loves electronics/music
« Reply #3 on: March 04, 2012, 10:21:25 AM »
He probably thought you were talking about an Epiphone Valve Jr.
And nope, never heard of any deaths by volume pedals. Unless somebody dropped it from a really tall building and it hit you in the head, I can't see any life threatening dangers in using a volume pedal case.
Logged
Ben N
Ben N. - really! Now Israel, once Baltimore
« Reply #4 on: March 04, 2012, 12:01:21 PM »
Those EB pedals are heavy. I'd bet they are life threatening even if dropped from a second story window.
Logged
mremic01
« Reply #5 on: March 04, 2012, 12:22:47 PM »
Yeah, I read EP as Epiphone and wasn't really sure what the P in VP would be. Sorry.
In that case, I really don't see why there would be any issues. Go for it.
Logged
spfautz
« Reply #6 on: March 15, 2012, 01:33:28 PM »
I'm also now considering adding a small voltage doubler like this http://diy-layout.com/20 before the circuit with toggle switch.  9v --> 3pdt toggle --> Voltage doubler---> EP Booster.
Is there a reason why this wouldn't work?
Has anyone used the EP Booster and feels like this is a useful addition?
Stefan
Logged
spfautz
« Reply #7 on: March 26, 2012, 03:03:43 PM »
Here is what I ended up with.  What do you think.?
Logged
joegagan
« Reply #8 on: March 26, 2012, 10:03:03 PM »
LooKs great! How does it sound, how is the taper and what do the controls do?
Logged
spfautz
« Reply #9 on: March 27, 2012, 09:20:17 AM »
It sounds great. The toggle is the on/off and the knob is the level.  The pedal itself isn't connected to the boost other than they are sharing the enclosure.  I thought about hard wiring the in's and out's of the volume pedal to the 3pdt, but I wanted to have the ability to put the boost at different places in the chain.
Logged
Pages: [1] Go Up Print
« previous next »
Jump to:
