EP Booster Clone in a VP Jr.
Started by spfautz, March 03, 2012, 11:25:11 PM
spfautz
I'm thinking about using the big empty cavity in my EB VP Jr. to hold my EP booster clone.  My idea would be to drill a couple of holes in the side for the power, pot, in and out.  Since I'm thinking about using it in a more always on pre amp type of way, I was thinking of a 3pdt toggle instead of a footswitch (its also coming out of the side which would be weird for footswitching).  Does this seem like a good idea?  Am I not considering something I should be?
Thanks,
Stefan
mremic01
I don't see why that wouldn't work. If you've never worked inside of a tube amp before, just remember to read up on how to discharge the filter caps. Those can hold a charge and kill you even when the amp isn't plugged in.
Nyt brenhin gwir, gwr y mae reit idaw dywedut 'y brenhin wyf i'.
spfautz
Tube amp?  I'm talking about my Ernie Ball Volume Pedal Jr.  Thanks for the concern.  For the most part I can't die from the volume pedal right?
blackcorvo
Quote from: spfautz on March 03, 2012, 11:53:53 PM
He probably thought you were talking about an Epiphone Valve Jr.
And nope, never heard of any deaths by volume pedals. Unless somebody dropped it from a really tall building and it hit you in the head, I can't see any life threatening dangers in using a volume pedal case.
She/They as of August 2021
Ben N
Those EB pedals are heavy. I'd bet they are life threatening even if dropped from a second story window.
mremic01
Yeah, I read EP as Epiphone and wasn't really sure what the P in VP would be. Sorry.
In that case, I really don't see why there would be any issues. Go for it.
spfautz
I'm also now considering adding a small voltage doubler like this http://diy-layout.com/20 before the circuit with toggle switch.  9v --> 3pdt toggle --> Voltage doubler---> EP Booster.
Is there a reason why this wouldn't work?
Has anyone used the EP Booster and feels like this is a useful addition?
Stefan
spfautz
Here is what I ended up with.  What do you think.?
joegagan
LooKs great! How does it sound, how is the taper and what do the controls do?
my life is a tribute to the the great men and women who held this country together when the world was in trouble. my debt cannot be repaid, but i will do my best.
spfautz
It sounds great. The toggle is the on/off and the knob is the level.  The pedal itself isn't connected to the boost other than they are sharing the enclosure.  I thought about hard wiring the in's and out's of the volume pedal to the 3pdt, but I wanted to have the ability to put the boost at different places in the chain.
