Pages: 1 [2]
Author
Topic: Cutting Vero and Perf Board- I cant do it! (Read 2181 times)
Perrow
Pelle T
+1 for dremel with diamond cutting wheels, it just cuts, then you can clean the edges with the same tool, and cut pot shafts. Get other diamond bits and you can adjust any hole you drill (outside the bedroom).
Logged
Bill Mountain
I've never had a problem just scoring with a blade of some sort and then snaping. Just like drywall!
Logged
claytushaywood
I use tin snips for pcbs. Might try sissors on the perf, if that doesn't work the snips will. Never tried to cut vero but guessing snips would work as well. Best thing is no dust. I used to use a dremel but very messy and bad for lungs.
I use a kitchen scissors , those buggers have lots of power ! Get those long ones . I like the idea of scissors. seems easiest for me, as I am lacking a vise or mask or goggles. I definitely dont want to dremel without a vise. Do you just cut the board with the scissors or do you have to score it at all? Does this method require file or sanding for smoothing edges? It seems like just cutting it with scissors would be prone to cracking the board?
Logged
Perrow
Pelle T
I'm hardcore, I dremel without a vise
Logged
seedlings
Chad B. KC, MO
I'm hardcore, I dremel without a vise  Me too; barehanded, without goggles  ...(just like when using the weedeater) Scorned, CHAD
Logged
DiscoVlad
This, score along the holes (think the perforations on a sheet of postage stamps) and snap.
Logged
Rob H. LONDON
eat 3 sausages, have a cup of tea, shout at a cat, then attack the vero with a chainsaw......then more tea...done!
Logged
J0K3RX
eat 3 sausages, have a cup of tea, shout at a cat, then attack the vero with a chainsaw......then more tea...done!  I shoot laser beams from my eyes and it cuts like butter every time!!  Just don't look away from the board when you are cutting  Then when I'm feelin lazy I just use heavy duty meat cutting scissors... both work real good  I'll give the 3 sausages chainsaw approach a try, sounds like a wiener to me!
« Last Edit: March 07, 2012, 07:52:38 PM by J0K3RX »
Logged
If it sounds good, then it is good...
Morocotopo
Ariel F. - Argentina
What has worked for me is, lay a metal ruler along the cut, if possible clamp the whole thing, then with a blade start marking along using the ruler as support for the blade. But the trick is to try to make a "V" cut, by tilting the blade to one side and then to the other on each pass. After you have deepened the cut to about half the veroīs depth, just snap it with a swift movement. If the cut is not deep enough it may snap outside the mark. Careful with the blades. Always make the "strokes" away from you, never towards you. Donīt use fingers to hold the ruler/vero, although Iīve been guilty of doing that.
I eventually got a Dremel.
Logged
Morocotopo
seedlings
Chad B. KC, MO
So sorry, but... Is there any nation with a Metal Ruler? You know, the guy who proclaims growling drop B tunings and wicked fast double kick throughout the land. Oh, I'd take a holiday to the land of the Metal Ruler... CHAD
Logged
g-sus
This, score along the holes (think the perforations on a sheet of postage stamps) and snap. This is how I do it and I think it's the easiest way.
Logged
Rob H. LONDON
eat 3 sausages, have a cup of tea, shout at a cat, then attack the vero with a chainsaw......then more tea...done!  +1 thats what i do too...i totally concur
Logged
Perrow
Pelle T
A brit that actually agrees with himself, I thought I'd seen it all
Logged
DavenPaget
Dave.S / Dave Seether
I tried scoring and my blade @#$%ed me up in the process , then i used my old friend the meat cutting scissors or my side cutting plier for the smaller boards .
Logged
Hiatus
iccaros
Steve H. - Lesser Seattle Area
Logged
gary from chicago
Get a vice. How can you live without one?
Logged
Perrow
Pelle T
"Get wise, get a vise" What makes you think I don't have one? I just don't use it.
Logged
Rob H. LONDON
A brit that actually agrees with himself, I thought I'd seen it all  +1 you need to get out more then...
Logged
Pages: 1 [2]
