|AMPAGE| |GEOFEX| |AMZ|
June 19, 2013, 10:19:19 AM
894959 Posts in 97886 Topics by 28965 Members
Latest Member: StaticRick
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  Digitech PDS Echo Plus Mix Pot? 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: [1] Go Down Print
Author Topic: Digitech PDS Echo Plus Mix Pot?  (Read 203 times)
Arn C.
« on: March 07, 2012, 09:36:43 AM »
Hello,
   Would the mix pot be linear or audio taper and if it is linear, could I use an audio taper in its place?
   This is a delay type pedal..
Arn C.
Logged
charmonder
Re: Digitech PDS Echo Plus Mix Pot?
« Reply #1 on: March 07, 2012, 11:07:37 AM »
That should be easy to change, the pots are pc mount but the legs are long enough. 16mm pots would probably be the biggest size pot youd get away with..
I think the mix pot might be linear, I haven't checked but I personally like it the way it is.
Logged
Pages: [1] Go Up Print
« previous next »
Jump to:
