Pages: [1]
Author
Topic: Digitech PDS Echo Plus Mix Pot? (Read 194 times)
Arn C.
Hello, Would the mix pot be linear or audio taper and if it is linear, could I use an audio taper in its place? This is a delay type pedal.. Thanks! Arn C.
Logged
charmonder
That should be easy to change, the pots are pc mount but the legs are long enough. 16mm pots would probably be the biggest size pot youd get away with..
I think the mix pot might be linear, I haven't checked but I personally like it the way it is.
Logged
Pages: [1]
