|AMPAGE| |GEOFEX| |AMZ|
May 18, 2013, 05:12:31 AM
890506 Posts in 97518 Topics by 28656 Members
Latest Member: ES
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  Fix a Biyang Tri Reverb- waste of time? 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: 1 [2] Go Down Print
Author Topic: Fix a Biyang Tri Reverb- waste of time?  (Read 2454 times)
Govmnt_Lacky
I'M ONLY GETTING CLEAN OUTPUT!!!!
Re: Fix a Biyang Tri Reverb- waste of time?
« Reply #20 on: March 20, 2012, 10:24:19 AM »
Does this mean IC6 is the clock?
I think that the 3201 chip is set up like the Spin Semi FV-1. Does not need an external clock. The clock and LFO are internal.
Hope that helps.  Grin
P.S. Of course, I could be totally wrong about this but, that is how the datasheet read to me  Tongue
Logged
for an amount of ‘up to and including my life.’
Ice-9
Mick T Newcastle England
WWW
« Reply #21 on: March 20, 2012, 10:44:20 AM »
IC9 is a digital reverb engine chip BD3201-14a
http://www.bdnc.com/datasheet/bd3201-14A_spec_V1.6.pdf
IC6 is a CS4340 is a D/A converter
http://pdf1.alldatasheet.com/datasheet-pdf/view/58109/CIRRUS/CS4340.html
IC7 ia a CS5340 A/D converter
http://pdf1.alldatasheet.com/datasheet-pdf/view/115334/CIRRUS/CS5340-CZZ.html
The other 3 chips are ST microelectronic EF797 dual op amps.
There is no clock chip , the main processor takes care of all that.
Logged
Rebel without a clue.
Paul Marossy
Just Another Guitarhead
WWW
« Reply #22 on: March 20, 2012, 10:48:43 AM »
Sounds like that's the essence of the pedal. So why won't it switch to effect on mode?! What is the most likely culprit with it apparently being a conventional 3PDT switch based true bypass pedal?
Logged
_/\_/\_PJM_/\_/\_
www.diyguitarist.com
www.soundcloud.com/Paul-Marossy
"Hi. My Name is Paul. I am a recovered stompboxaholic."
anchovie
James H, UK
« Reply #23 on: March 20, 2012, 10:53:38 AM »
Any of the above!
An audio probe will give an easy check of opamps in the audio path and the output of the D/A converter. I guess you'd need a scope to see if the A/D and 3201 outputs are working.
Logged
- Guitar built from parts
- Random strings to make a full set
- Any pick that I can find on the floor
- Some pedals that I built
- My all-tube amp head that I built out of parts in my spares box
- Cheap Marshall 4x12 with better speakers fitted
Govmnt_Lacky
« Reply #24 on: March 20, 2012, 10:54:36 AM »
I would start by making sure that the 3.3V regulator is functioning as this is what the processor, D/A, and A/D are powered by.
If it is anything like the FV-1, it REALLY, REALLY needs that voltage to be AT LEAST 3.3V to work well.
Logged
Paul Marossy
WWW
« Reply #25 on: March 20, 2012, 11:00:46 AM »
+1. Sounds like a good place to start. Easy to verify with a DMM.
Logged
_/\_/\_PJM_/\_/\_
seedlings
Chad B. KC, MO
« Reply #26 on: March 20, 2012, 11:48:54 AM »
Dirty dog!
I went to check some voltages at lunch and the thing came on!  While it was on I tapped around with the chopstick to see if it would glitch, but no!  icon_question icon_question icon_question
 Huh
CHAD
Logged
Paul Marossy
WWW
« Reply #27 on: March 20, 2012, 12:46:56 PM »
Doh! This is one of those weird intermittent problems that can drive you nutz!  icon_confused
Logged
_/\_/\_PJM_/\_/\_
Quackzed
Gil Feeney
« Reply #28 on: March 20, 2012, 03:24:27 PM »
you got gremlins...
Logged
sudoku...?  pffft!!!!    VERO!
Paul Marossy
WWW
« Reply #29 on: March 21, 2012, 08:34:58 AM »
Is that what an electron gremlin looks like?
Logged
_/\_/\_PJM_/\_/\_
seedlings
Chad B. KC, MO
« Reply #30 on: March 21, 2012, 09:14:54 AM »
I didn't feed it after midnight, and I hummed that cool song it likes  Grin
Re-boxed and it still works.  Like I said, it's done this before, just not for this long.  I did notice one thing that may or may not make any difference.  The stereo input jack is wired so that a cord has to be inserted for it to power up on batteries and via DC adapter.  When the pedal is powered, and then the input cord is inserted, it takes about one second for the LED and effect to come on.  Is this suspicious at all to you?
CHAD
Logged
WWW
« Reply #31 on: March 21, 2012, 09:38:48 AM »
Not at all.
Typical wiring is that the input jack makes a ground connection for the power supply when a plug is inserted, and does not discriminate which sort of power supply it may be.
It may be the case that the delay for powering up is a reflection of a) a big power supply cap that takes a moment to charge up, or b) some routines that the digital side of things has to go through before signal can be passed.
Logged
jubal81
« Reply #32 on: April 15, 2012, 02:46:41 PM »
I had the same problem and after about an hour of poking around I got it fixed. The transistor in the red square was toast. I replaced it with a BS170 and the pedal came back to life.
I was sure I was just gonna have to chuck it. Whew!
Logged
Pages: 1 [2] Go Up Print
« previous next »
Jump to:
