MN3007 Equivilent
Started by John Egerton, August 22, 2003, 10:10:48 AM
John Egerton
Hi dudes.. I'm having trouble finding an MN3007 for a small clone build. Can anyone list me some equivilents?
John
Save a cow... Eat a Vegetarian.........
hank reynolds 3rd
the mn3207 will work ,the only difference is the 3007 has a max voltage of 15v,whereas the 3207 runs at a max of 10v...i think
sam
John Egerton
so it wouldn't really matterif it is being used in a 9v effect pedal??
John
smallbearelec
John--
I have both the 3007 and the 3207, though the latter is far cheaper because Chinese-made clones of it remain in production. The low-voltage chip has been used in a number of commercial chorus designs, and I believe some DIYers have also worked with it successfully.
Regards
Steve Daniels
www.smallbearelec.com
Joep
THAT IS NOT ALL!!
You need to switch pin 1 and 5 around. The MN3007 is for negative power supply voltages and the MN3207 for positive power supply voltages.
The MN3207 can be used up to 11V abs. max. Some of the Wall-wart powersupply give you 12V instead of the 9V that's written on them, so you have to take care if you use them.
Bye,
Joep
Aharon
I buy NTE1641,it's a direct sub and seems to be easier to find and cheaper.
Aharon
Aharon
