Author Topic: 4: Switches/Bypass/Etc....  (Read 173529 times)
Lanky
« Reply #20 on: January 18, 2004, 09:45:29 PM »
Nvm, got it.
aron
« Reply #21 on: January 19, 2004, 01:36:39 AM »
I've always heard Jay-FET and L. E. D.
Aron
smoguzbenjamin
« Reply #22 on: January 19, 2004, 10:20:59 AM »
Usually I say led because it's quicker :)
sonofdirt
its alive! how do i kill it?
« Reply #23 on: March 25, 2004, 06:25:07 AM »
hey this is great! I think i've got it working, woohoo my first circuit! My only problem is that the input jack switching is not working... in other words, the power is running all the time and is not switched off when the plug is removed from the input jack...
as far as i can tell i've wired everything as shown... the only strange thing i ran across is that my mono output jack has 3 terminals instead of 2. Can you suggest a place to start troubleshooting?
also, just to make sure, the circuit is supposed to work like a volume knob of sorts correct??
thanks.
- Brian
i think i'll take on the BrassBlaster Bass Overdrive project next; anybody know of any other good Bass pedals to build?
sonofdirt
followup
« Reply #24 on: March 25, 2004, 07:48:13 AM »
i think if someone gave me a thorough explanation of how the LED and stepdown resistor should be wired to the inputjack switch it would help alot. The only example of mounting the LED i see involves attaching it to a 3PDT switch... when the 3DPT is taken out of the equasion, the LED seems to have a constantl ycompleted circuit rom + to - on the 9V battery.
This is where im stuck. The LED is on no matter what and I am unable to tell if the rest of the circuit is drawing power form the battery with no plug inserted either. Am I making sense?
i appreciate the assistance.
smoguzbenjamin
« Reply #25 on: March 25, 2004, 10:30:46 AM »
Well if you connect the LED/resistor combo to ground, and it's drawing current even without any plug inserted, you've miswired your input jack switch. Are you sure you wired the jack OK?
slackhammer
« Reply #26 on: March 27, 2004, 05:55:05 PM »
Would it be possible for someone to post a picture of their bypass wiring box?
aron
« Reply #27 on: March 27, 2004, 07:37:53 PM »
The key is that the LED ground should connect to the SLEEVE of the input jack. Once you do this, when you unplug your guitar cable, the ring will not be connected to the ground of the input jack and the circuit is disconnected.
See the picture in this thread on how to connect the input jack.
gdmart
LED long leg short leg
« Reply #28 on: April 15, 2004, 12:47:15 AM »
I have forgoten is the short leg of the led + or - thanks
aron
« Reply #29 on: April 15, 2004, 04:21:41 AM »
The more important thing is that the flat side of the LED is the cathode or "line" in the symbol:
gdmart
Led wiring
« Reply #30 on: April 15, 2004, 10:32:50 AM »
so the cathode goes to ground or the antode to ground???
aron
« Reply #31 on: April 15, 2004, 02:00:06 PM »
Sleeve is ground in this picture.
jjucius
« Reply #32 on: April 15, 2004, 07:05:40 PM »
question, i'm putting 3 effects in one box. only 2 jacks in and out. do i run the out from one switch to the in of the next? and hook the effects to the in and outs of the switches?
Joe
aron
« Reply #33 on: April 15, 2004, 09:25:51 PM »
yes.
hubble
« Reply #34 on: April 24, 2004, 04:45:09 PM »
aaron, on that board what are the input outputs?
on the GGG site he explained that the output on the board is usually the middle lug of the level pot.  so whats the input?
aron
« Reply #35 on: May 20, 2004, 03:48:04 PM »
Here you go.....
bazzwazzle
« Reply #36 on: September 06, 2004, 06:19:57 PM »
when using the bypass, will i still have to have the 9V+ connected to the resistor, just the lug on the switch, or both?
bazzwazzle
« Reply #37 on: September 08, 2004, 09:17:22 PM »
arg, it worked earlier and now when wiring up the bypass it's not working again.  :cry:
aron
« Reply #38 on: September 08, 2004, 09:51:25 PM »
It has to be something simple. Just triple-check your connections.
bazzwazzle
« Reply #39 on: September 08, 2004, 10:18:49 PM »
Aron could you answer my above question please also? :)
thanks
