|AMPAGE| |GEOFEX| |AMZ|
May 17, 2013, 11:49:23 PM
890481 Posts in 97517 Topics by 28656 Members
Latest Member: ES
Home Help Login Register
DIYstompboxes.com  |  Projects  |  Beginner Project  |  4: Switches/Bypass/Etc.... 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: 1 2 3 4 5 6 [7] 8 9 Go Down Print
Author Topic: 4: Switches/Bypass/Etc....  (Read 105214 times)
aron
Administrator
Aron Nelson
Re: 4: Switches/Bypass/Etc....
« Reply #120 on: July 19, 2008, 12:09:31 PM »
It goes to the board. Then at the board you run a wire to the switch.
Logged
chrisbtz
« Reply #121 on: July 19, 2008, 01:52:31 PM »
kewl thanks. I hope to build this this weekend. I'll post if anymore questions arrise.
Logged
vortico
« Reply #122 on: January 08, 2009, 05:03:36 PM »
This is a total noob question, but if guitar cables are unbalanced and mono, why a stereo input?
Logged
aron
Administrator
Aron Nelson
« Reply #123 on: January 08, 2009, 05:30:59 PM »
Great question and time for you to read the FAQ link above. Specifically look at the JACKS section:
http://www.diystompboxes.com/wiki/index.php?title=DIY_FAQ
Logged
vortico
« Reply #124 on: January 10, 2009, 01:06:57 PM »
Ah, I see. That makes sense. Thanks.
I'm in the process of reading the entire FAQ. It's great so far!
Logged
NumBass
Dallas O. - Wisconsin
« Reply #125 on: January 16, 2009, 10:24:21 PM »
the only switches i can get around here are on/off switches.    like....... two connectors.......either connected or not connected (lol)   is there any way to make these work?
Logged
aron
Administrator
Aron Nelson
« Reply #126 on: January 17, 2009, 12:07:13 PM »
That's not enough connectors unfortunately. There's a STORE link above :-)
Logged
NumBass
« Reply #127 on: January 17, 2009, 10:39:02 PM »
alright...thought id ask lol.   im ordering them now Cheesy
Logged
NumBass
« Reply #128 on: January 18, 2009, 04:00:59 PM »
alright another ?.... ,While im waiting for my switch to come in, do u put the 47 uF Cap behind the 5K Pot, and then hook that to the 47K and 100K resistors that go to ground, or does the Cap and Pot go after the resistors??
BTW - im almost done but it looks REALLY crappy (the soldering job) because the last time i soldered was two years ago and cuz all we have right now is a thick gauge solder Cry    I think it should turn out fine though, hopefully, lol.
(note to self: go buy thinner solder...*scribbling noises*)
Logged
NumBass
« Reply #129 on: January 26, 2009, 03:21:51 PM »
soooooo its been like two weeks and no one has answered my ? above ^.......could anyone answer please??
Logged
Gordon
« Reply #130 on: April 15, 2009, 08:07:46 PM »
Hello!
I am using a DPDT switch for the bypass. When the bypass is engaged, the sound is fine, but when I switch the effect on, all I get is a quiet hissing sound. As I turn up the potentiometer, the hissing gets louder, but there is still no sound from my guitar. What should I do?
Logged
aron
Administrator
Aron Nelson
« Reply #131 on: April 15, 2009, 09:02:41 PM »
It sounds like the circuit is working and that somehow you have mis-wired the switch so the circuit doesn't get signal. Alternately, you have a bad solder joint right at the beginning of the circuit and your guitar signal is not reaching the base of the transistor.
Aron
Logged
Voodoo Blues
Mike P
« Reply #132 on: July 28, 2009, 08:27:36 PM »
Here is a version with the DC jack:
Aron, Why isn't ring lug on the input jack needed in the circuit with the DC jack is engaged?
When I looked up the connection diagram of the DC Jack it said to connect one lug to board - and battery - (see link) but that's not the way it's hooked up in the above picture.
Http://www.smallbearelec.com/Detail.bok?no=93
Logged
Who put a fog machine in my pedal?
aron
Administrator
Aron Nelson
« Reply #133 on: July 28, 2009, 08:58:52 PM »
It should work fine as above. The ring is used to turn the circuit off when the battery is used. When the battery is not used, then you don't need to worry about switching it on or off. Of course you can connect that DC jack tab to the ring too if you want.
Logged
Voodoo Blues
Mike P
« Reply #134 on: July 30, 2009, 06:21:18 PM »
That's the way I have it wired right now, I just wasn't sure if it would work (bypass the battery). Thanks Aron.
Logged
GarySpence
« Reply #135 on: August 05, 2009, 11:28:14 AM »
Hi Everyone,
So, finally got the boost built. Happy days! LED and switch working fine. The only thing is that instead of boosting the volume, when clicked on it actually reduces the volume!!! As the effect is working in reverse I assume I've soldered one of the components back-to-front? Any ideas what this could be as I can't see what it is I've done wrong. Where should I start... Smiley Despite that I had a blast doing this!
Cheers
Gary
Logged
.Mike
Mike - Savannah, Georgia USA
WWW
« Reply #136 on: August 05, 2009, 12:08:52 PM »
Hi Everyone,
Cheers
Gary
Hi there,
If I recall correctly, having the transistor backwards can cause a reduction in gain instead of a boost.
Double-check the orientation of your transistor. If you look at the schematic, it lists B, C, and E. Google the transistor you used along with the word "datasheet." The datasheet will show an image of your transistor, and list which pins are B, C, and E. Make sure the right pins are connected to the right place.
Smiley
Mike
Logged
If you're not doing it for yourself, it's not DIY. Wink
My effects site: Just one more build... | My website: America's Debate.
aron
Administrator
Aron Nelson
« Reply #137 on: August 05, 2009, 12:58:57 PM »
Make sure you also have power going to the transistor. Use your meter to measure the DC voltage at the pins of the transistor. Put the black on ground and use the red probe to measure the voltages at the pins.
Logged
GarySpence
« Reply #138 on: August 05, 2009, 01:47:54 PM »
 Huh
Thanks Mike. Got the datasheet and check the pins were in the right sockets. What strange is that the sound of the the effect stays the same no matter what what the transistor is connected . It's the same when I take it out too!
Hey Aron. Black to ground and red to a pin at a time. Nada. Could the .1uf Capacitor be the wrong way round or does this not matter?
Logged
aron
Administrator
Aron Nelson
« Reply #139 on: August 05, 2009, 02:00:01 PM »
What does this mean? No voltage reading?
Logged
Pages: 1 2 3 4 5 6 [7] 8 9 Go Up Print
« previous next »
Jump to:
