Has this circuit been verified ?
Started by HOTTUBES, April 13, 2012, 08:57:54 PM
rousejeremy
If it's Renegadrian I'd say you're pretty safe.
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
timd
I might try it if some time frees up. I would either build it on a breadboard first, or use a socket so you can test other transistors. Anyone know what makes it "boutique"?
HOTTUBES
The reason i asked is that i built this circuit and i can not get it working ....
I have switched around the tranny , tried a new one as well , double and triple checked all solder's / connections ...
It will pass audio , but all i get is very low out put with and no overdrive at all , it remains clean at all times .
gruemungus
What diodes did you use? D1 should be 1n4001 and D2 1n4148
LucifersTrip
check if the connections are the same as the verified one:
http://www.aronnelson.com/gallery/main.php/v/Lenwood-Designs/Perfboard-Layouts/BoutiqueNPN_OD.gif.html
...and remember troubleshooting starts with the voltages. you need to compare yours to working ones.
always think outside the box
rousejeremy
The layout you built lloks good compared to the verified one Luciferstrip posted.
Take voltage readings. Remember R.G's words "Remember that for an NPN silicon transistor to be working as a linear amplifier, it MUST have its base higher than its emitter by about one silicon diode drop, 0.5 to 0.7V, and the collector must be higher than either base or collector. The collector-to-emitter voltage is the size of the negative half signal swing, and the power-to-collector voltage is the size of the positive half signal swing."
HOTTUBES
Quote from: gruemungus on April 14, 2012, 02:34:37 PM
I used a pair of 4148
Does it make a difference what one you use here ???
HOTTUBES
I will post voltages later tonight .....
Thanks for your help !!!!!
rousejeremy
Quote from: HOTTUBES on April 14, 2012, 05:41:03 PM
Your diode substitution wouldn't cause the problem you've described.
HOTTUBES
Quote from: rousejeremy on April 14, 2012, 09:04:28 PM
I will try a 1n4001 and 4148 , and report back ....
HOTTUBES
With my circuit build , i used a 220PF cap instead of a 330Pf for C1
Would this be a problem ? I did not have 330 pF on hand .....
HOTTUBES
timd
This difference appears very small, and I don't believe that substitution is the cause of the issue. I would investigate elsewhere...
rousejeremy
HOTTUBES
Oh yeah , i was gonna post some voltages at the tranny's D G S !!!    I forgot oops !
HOTTUBES
Boutique NPN OD
2N5089
E - .675 v
B - 1.311  v
C - 6.55 v
open battery volts - 9.4 v
HOTTUBES
Toney
#18
 Layout like fine vs the perf you certainly should have some output.
What is it? Do you have a schem?
It pretty simple - go over it with a continuity tester or loupe/magnifying glass looking for solder bridge poor joints. Also are the resistor values def correct? Transistor should be orientated as per the layout if its a standard 2n5089.
Its a amazing what completely leaving things for a day or two can do too.  You often go back to it and immediately see the issue.
Have had many such "doh" moments  :P
HOTTUBES
