True bypass loop with blend-in option I came up with...
Started by alex_spaceman, April 14, 2012, 05:29:25 PM
alex_spaceman
Hi everyone,
I've been looking into re implementing my old Yamaha Magic Stomp into my set up as a reverb, but I want to get rid of it's buffer.
I want to be able to both blend in reverb to my clean signal and use 100% wet settings, so I came up with this wiring design which should be able to offer me both options at the press of a footswitch. All the reverbs would be set on 100%.
Haven't put it together yet, but looking for some feedback from more seasoned builders... It looks as if it should work to me.
About the buffer, I'm not 100% whether I'll actually need, but should give me more room to play around with the volume control for the amount of reverb to blend in. Also, any suggestion as per which kind of booster I should adopt is more than welcome.
Thanks for your attention, and hope others can benefit from the design too and/or can add or make good changes to it. Here's a diagram of it:
Alex
