Problems With BYOC Classic Compressor and a Clyde McCoy Wah Clone
Started by Major Sparky, April 14, 2012, 08:36:38 PM
Major Sparky
I'm having a similar problem with both of these effects.  When I'm using the wah pedal I'm getting a crackling/popping sound in the middle of the pedals sweep.  With the classic compressor I get a small pop when I turn the sustain knob around 3 or 4 o'clock, also the sustain knob doesn't seem to be adding much compression at all. There's no difference in sound until I turn the knob past 2 o'clock.
At first I though that the pots were just dirty/scratchy, but I cleaned them and it hasn't had any effect.  I went back over all of my solder joints on the classic compressor and it's still acting the same way.  I haven't done this yet with the wah pedal.
I used this schematic for the wah pedal, http://fuzzcentral.ssguitar.com/mccoy.php  and here's the instructions for the classic compressor, http://www.buildyourownclone.com/2knobcompressorinstructions.pdf
Besides these problems the pedals work fine.  LED lights up on the compressor and the level knob works well.  The wah does just what it's supposed to.
Any insight?
frankie5fingers
I can't speak to the pop, however, there are a couple of ways of rewiring the 3PDT the reduces/eliminates the pop.  IME, the "scratching" noise in the wah was Q1 saturating and and clipping.  I upped the value of the emitter resitor that cleared it up.  In my case I socketed that resistor position.  I used 1% tolerance, but bought a few values in 1%, 2% and 5%.  I experimented with a few and found that a 2% tolerance unit about 50% higher than the original cured the scratching completely.
