turn a 100k pot into a 5k ?
Started by petey twofinger, April 17, 2012, 09:11:54 PM
petey twofinger
i have a need for a dual 5k a pot , the ones i have , the shaft is short .
i do ahave a long shaft 100k dual a pot , is there a way , like adding what value resistor to this to "make it a 5k pot" ?
its for a smalley npn boost , a stereo one .
the pot is wierd with 2 wires going to it . there is a cap in there on the pot as well .
thanks !!
im learning , we'll thats what i keep telling myself
LucifersTrip
Quote from: petey twofinger on April 17, 2012, 09:11:54 PM
thanks !!
http://diyaudioprojects.com/Technical/Electronics/parallel-resistor-calculator.htm
but remember the sweep will greatly change. you can read numerous threads about it here and:
http://www.geofex.com/Article_Folders/potsecrets/potscret.htm
http://www.dirk-hendrik.com/temp/pottaper.gif
always think outside the box
could a trimpot on it work... and adjust?.   just thinking aloud!.. :P
petey twofinger
i tried this last night , added a 1m to pins 1 and 3 on the pot . it didnt work . i am guessing this works with a 3 wire hookup , this was only a 2 wire connection to the pot . thanks for the assist guys !
i just wanted to avoid cutting too large of a hole in the "thick" wood chassis .
its this OLD speaker box i got off CL free . a capitol records speaker , from a turntable set up . it is such a nice looking retro piece .
the guy i got it from looked like a real burn out type ...
after working on it for 3 days i noticed he had pencil drawn a hairy male organ inside the chassis , and had written " 6 inches" .
(my wife AND BOTH daughters had been helping me on this project)
someone had also taken an "el morko" giant tip permanent marker and scrawled " 15 dollars AS IS ! " on the bottom and back panel .i cut a new piece for the back panel , stained and clear coated that , but , the ink never came off the bottom . the "artwork" on the inside was promptly erased .
i feel oddly tempted to swing by the guys place , throw the amp on the roof of the volvo , CRANK  it , and throw down some super cheesed weedily wee two finger tapping  .
i got yer 6 inches , buddy .
but i did get 2 working bass tens from this guy for free so  .
anyway , this amp is pretty sweet .
video soon .
