Pages: [1]
Author
Topic: Tiny power jacks (Read 1655 times)
Taylor
The clean energy source of the future.
I know I've seen some people using some very small power jacks in their pedals here. I am looking for something like those.
I would prefer something that screws onto the enclosure rather than a snap-in part or something meant to mount only to a PCB. I don't ever use battery power, so I don't need an extra terminal for battery switching. The smaller, the better. Anyone have any leads on a part number or supplier for these?
« Last Edit: April 21, 2012, 04:54:28 PM by Taylor »
Logged
Taylor
Logged
JebemMajke
Miša Živanović
@Earthscum i have like 6 of those and i hate them just because of sleeve. Any advice on how to isolate them?
Logged
Earthscum
Lol... advice on isolating them... hmm. 1 option is to buy plastic sheet (1-1/16" thick) and drill large hole in the enclosure so the jack won't touch, and some smaller holes to mount the plastic plate you make with some bolts or screws. Then you can mount the jack to the plate, and it is electrically isolated from the enclosure. I found some parts at the hardware store to make a neat little isolator (although I drilled the hole in the wrong place initially  ). I should put up a quick thread about it...
Logged
Taylor
Hey SD, cool. Do you have a mechanical drawing of that, or any sizing info? I'm trying to find out if it's small enough for my needs.
Logged
electrosonic
Andrew
I think those are made by mode electronics - or sold by them anyways (not a switching jack though)  Andrew.
Logged
smallbearelec
Do you have a mechanical drawing of that, or any sizing info? Yea, drop a message to the smallbearelec address and I will reply with the mechanical.
Logged
JebemMajke
Miša Živanović
Lol... advice on isolating them... hmm. 1 option is to buy plastic sheet (1-1/16" thick) and drill large hole in the enclosure so the jack won't touch, and some smaller holes to mount the plastic plate you make with some bolts or screws. Then you can mount the jack to the plate, and it is electrically isolated from the enclosure. I found some parts at the hardware store to make a neat little isolator (although I drilled the hole in the wrong place initially  ). I should put up a quick thread about it...  Really thought there is a better way to do that. Anyway thanks.
Logged
The Tone God
Global Moderator
Linda
1 option is to buy plastic sheet (1-1/16" thick) and drill large hole in the enclosure so the jack won't touch, and some smaller holes to mount the plastic plate you make with some bolts or screws. Then you can mount the jack to the plate, and it is electrically isolated from the enclosure. You mean like this:   Andrew
Logged
Rob H. LONDON
^ i use those all the time...nice 8mm hole....not those 12mm @#$%ers...
Logged
Pages: [1]
