Millenium 2 bypass led not working
Started by Perrow, April 23, 2012, 05:43:53 AM
Perrow
For some reason I can't get this millenium 2 led to light up, hopefully someone can spot an error.
Red for 9V+, blue for ground, and green pad for the control connection.
Had it sort of working with a 3mm led, but it was too dim, reduced the led resistor, but then it wouldn't turn off completely, just dim a little. Couldn't get 5mm leds to light up, even with the 3904 removed. Tried different leds, 4148 J201 and 3904. Verified with my meter that the 4148 actually leak (~900M resistance measured  :icon_eek:).
is it the base/emitter of the 3904 connected on the diagram...is that right?...
Perrow
Quote from: deadastronaut on April 23, 2012, 06:27:20 AM
I have checked the pinout more than once, I can check it again, but I'm reasonably sure I've got it right. Anyway, without the 3904 it should work (light up), and it doesn't.
mr_deadmaxxx
the one on the schematic is a MOSFET.
Perrow
Quote from: mr_deadmaxxx on April 23, 2012, 07:07:36 AM
Lots of people report good result using J201s for the FET, though when looking at this page and the datasheets for J201 and MPF102 I think I should try the MPF102 in that spot.
Only the collector and base is connected in my layout and from what I can tell it is how it should be. The pinout for 2N3904 is EBC.
Quote from: deadastronaut on April 23, 2012, 07:21:10 AM
^ yep..
http://www.aronnelson.com/gallery/main.php/v/diyuser/Sundgist/Millenium+2+Stripboard.gif.html
any help?.. :)
Yes, but as noted to D'Astro and in the link, J201 and MPF102 should work but with not much forward current (little or no led resistor if I understand it correctly).
I'll try and report back.
mr_deadmaxxx
been using this one. simple circuit.
adjust 1.5K resistor for LED current/brightness (depends on LED)
adjust 2K so that LED totally shuts down when Control is connected to ground (decreased value results in a dim light; increased value shuts down LED completely; depends on LED) ;D
merlinb
#8
Quote from: Perrow on April 23, 2012, 07:33:08 AM
FETs have very wide tolerance. For ideal operation you want the Vgs(off) rating to be much less than the LED forward voltage, and some J201s will barely manage that with a standard red/yellow/green LED.
You could try subbing a a blue or super bright LED (high forward voltage), or try different J201s, or use a MOSFET (which is guarenteed to work).
Quotebeen using this one. simple circuit.
Your 1n4148 is backwards!
Perrow
Quote from: merlinb on April 23, 2012, 10:37:05 AM
Guess I'll have to breadboard this one and select components. Don't have any MOSFETs at hand (will order) so until they arrive I'll experiment with the JFETs I do have.
mr_deadmaxxx
not really. i use this configuration with DSG Fets like J201 or 2N5486.
I only reverse 1N4148 when I use DGS Fets like 2N3819.
1n4148 cathode is always on V+.
Earthscum
Don -  From your schem, the way I see it working is that you are using the Jfet as a diode... Control goes high, gate goes high, Jfet works like a jfet. Control goes low, looks like it works as a shunt, no control voltage, should just work like putting V+ through a diode before it goes to the LED Anode. ???
merlinb
#12
Ah sorry, I assumed the upper line was V+. Didn't look closely!
mr_deadmaxxx
Earthscum
Perrow... on your layout, the jfet's Drain and Source are reversed. If you drop a MPF102 in there, it may not turn off all the way (some take near 4.5V to turn off... I love them to death, but tolerances suck... wish they would've batched them like Japanese). The MPF would, however, work in reverse, if you can get it to pull off completely. I really don't know how well that J201 is working with D and S reversed.
Personally, my absolute favorite for Mill bypass is the 2SK117GR from Tayda. Very low Vgs off and higher IDSS ( like the gate of a J201 with the channel resistance of a 2N5457).
mr_deadmaxxx
As for me, 2N3819, 2N5484, 2N5485 and 5486. :D
frank_p
If I remember well I had trouble with a millenium II:  Not all mosfets will work optimally in the circuit.  I had to get back to the 2n7000 in my case.
There are also these other options:
http://www.geofex.com/Article_Folders/Millenium/The%20Next%20Millenium.pdf
Perrow
I thought S was supposed to be on the positive side and D closer to ground, or? J201 being DSG and the middle pin being the positive I was positively sure I nailed that part. It should be the other way?
frank_p
Quote from: Perrow on April 23, 2012, 12:14:35 PM
Drain to positive, gate to switch, source to LED.
Perrow
Quote from: frank_p on April 23, 2012, 12:09:15 PMI had to get back to the 2n7000 in my case.
Those are 8 cents each from Tayda, I'll see if I can save up to buy a few :D
