Acceptable tolerance for substitute transistor
Started by Samnunn92, May 04, 2012, 11:40:30 AM
Samnunn92
Hi all,
This is my first post on the forum and I'm really getting into repairing and hopefully eventually building my own pedals. However I am a huge newbie so I have hopefully not too stupid a question: I am trying to repair an old Vox 1905 chorus pedal which has one or more failed transistors in it. The transistors that have failed are part number C1815Y but I am having real trouble locating these; apparently they are now obsolete, so I was wondering what would be an acceptable replacement? I was recommended a BU128 by a Digikey tech support rep but am not sure if it will be suitable as a replacement.
C1815Y datasheet: http://www.alldatasheet.com/datasheet-pdf/pdf/53347/FAIRCHILD/KSC1815Y.html
BU128 data info: http://english.electronica-pt.com/db/cross-reference.php?ref=BC128
Thanks a lot!
Sam
Those are actually 2SC1815Y, which is the yellow gain group for the 2SC1815. If the 1815 has gone obsolete, I haven't heard. I use them a lot.
Mouser lists them in stock in the green gain group, which is about twice the current gain. I'd grab some from Mouser and whip them in.
frank_p
Quote from: R.G. on May 04, 2012, 12:34:20 PM
Where can you find the color code for japanese transistors ?  I have some and don't know where to look to know.
frank_p
Samnunn92
Hi R.G thanks very much! So it doesn't really matter too much about the gain group then in this application?
