Author Topic: Zombie chorus with anti tick mod 1590b layout?..  (Read 44893 times)
0 Members and 1 Guest are viewing this topic.
Re: Zombie chorus with anti tick mod 1590b layout?..
« Reply #60 on: May 28, 2012, 06:01:30 AM »
this'll be ok with 2n3904's and a 3906 wouldnt it?...i'll socket those anyway though!...just in case!. :)
oh hold on, i think i have 5088's...
gonna have to sub a few bits in this,  haven't any 39k's..just 33k's,  ::)
no 3.3n's  or 15n's...  or 2.7n... :(
got    2.2/4.7     10/22        2.2 ::)...i'm sure it'll be ok, just tonally different i guess... ;)
i'll keep track of what i sub... ;)
http://www.youtube.com/user/100roberthenry
http://deadastronaut.wix.com/index
^ NANO-8 /CHASM REVERB / TREMSHIFTER / FAZE FILTER/ABDUCTOR II DELAY pcb's + WAH LIGHT PLATES.
Scruffie
« Reply #61 on: May 28, 2012, 07:31:32 AM »
3904 & 3906 work fine in the Small Clone.
With those vales, you'll change the frequencies of the filters, so you could end up with a darker pedal or one that lets clock noise through, probably be fine though.
Those 3007s... you tested them in a working pedal? All the same date code  :-\
« Reply #62 on: May 28, 2012, 07:42:33 AM »
cheers scruffie:
nope not tested at all...not even started... :D
edit: just read the mn3007's
says: mn3007   9N   ...all of them.. ???
« Last Edit: May 28, 2012, 07:48:38 AM by deadastronaut »
Scruffie
« Reply #63 on: May 28, 2012, 07:53:16 AM »
cheers scruffie:
That's what I found questionable... they could all be from the same batch of course, or they could also be from the same faking stamp...
« Reply #64 on: May 28, 2012, 07:54:32 AM »
hmmmmmmm.....oh @#$%!.. :'(
yeah same as pelle's..
oh well soon find out.. :-\
Perrow
Re: Sv: Zombie chorus with anti tick mod 1590b layout?..
« Reply #65 on: May 28, 2012, 08:52:27 AM »
... or we'll file a group action :)
Perrow
Re: Sv: Re: Zombie chorus with anti tick mod 1590b layout?..
« Reply #66 on: May 28, 2012, 08:54:56 AM »
I'm just short of the 33nf. Everything else is on the board already ;D
My Zombie is good to go as soon as I've wired up pots and jacks.
Perrow
« Reply #67 on: May 28, 2012, 10:31:19 AM »
Wired up the Zombie, sound but no chorus :'(
Scruffie
« Reply #68 on: May 28, 2012, 10:31:42 AM »
Voltages?
Perrow
« Reply #69 on: May 28, 2012, 10:41:20 AM »
Any special IC? I can see that the lfo works and I get sound through the circuit, so here goes 4046:
1: 0
2: 8.98
3: 0
4:4.5
5:0
6:0.97
7:0.95
8:0
9: fluctuates around 4.4
10 and 11: fluctuates around 3.3
12:6.91
13:0
14:9
15:0
16:9
3007:
1:9
2:9
3:5.4
4-6:0
7:6.5
8:6.5
Scruffie
« Reply #70 on: May 28, 2012, 10:58:25 AM »
2 & 6 of the 3007 should have approximatley half voltage, what are there voltages without the 3007 in there?
Perrow
« Reply #71 on: May 28, 2012, 11:11:33 AM »
The same (pin 7 & 8 are 8.6 though).
Perrow
« Reply #72 on: May 28, 2012, 11:15:48 AM »
Pin 2 drops to 0 after a while but goes back to close to 9 if I poke around a bit on the other pins.
« Reply #73 on: May 28, 2012, 01:26:13 PM »
i was just about to make a start on mine!.. :icon_eek:
got your jumpers on there?..
« Last Edit: May 28, 2012, 01:38:49 PM by deadastronaut »
Perrow
« Reply #74 on: May 28, 2012, 06:21:35 PM »
Just one jumper,but yes.
Perrow
« Reply #75 on: May 28, 2012, 07:10:56 PM »
Found that my layout shows pin 3 of the 4046 connected to pin 6 of the 3007. The schematic has pins 3 & 4 of the 4046 connected to pin 6 of the 3007.
I'll correct that and report back.
Sadly this is a day of planned activities as well as work. After work I have three meetings/activities to attend before I can get some DIY time.
« Reply #76 on: May 28, 2012, 08:54:10 PM »
2 jumpers.   top left+ bottom of 4047...
pin3 of 4047 is connected to D2...you mean pin 4 of the 4047?, which is connected to 4,5,6 at the mo..
busy day , i won't harrass you then.. :D
I'll take a look art the schemo.. ;)
Perrow
« Reply #77 on: May 28, 2012, 09:29:58 PM »
I'm on the Zombie  ;)
« Reply #78 on: May 28, 2012, 09:35:06 PM »
ahhh i see.... ;)
i wondered why you said 4046... ;D
i'll crack on with the smally then... ;)
« Last Edit: May 28, 2012, 09:36:37 PM by deadastronaut »
Perrow
« Reply #79 on: May 28, 2012, 10:40:15 PM »
Just looked and the 33nf cap I'm missing to complete my Small Clone is the input cap, guess I'll be ok with a 47nf there  ::)
I'll try that too tonight. Or more likely tomorrow night, will have to clear out everything on our balcony tonight (after the meetup with my sons new preschool class, a picnic with daycare, and an information meeting about renovations to our housing cooperative, did I mention I'm at work?) so the contractor that'll change the windows can dump the new ones there tomorrow morning.
