So..................as they dont make 12PDT foot switches!?
Started by carboncomp, May 09, 2012, 07:25:34 PM
carboncomp
Was having a conversation today about the best way to do something a little extreme, have a muff with a switch that would select between 2 sets of transistors.
I was thinking a 12PDT Latching Changeover Push-Push Switch (if they even make them!) may work, but would love to hear other peoples thoughts on here.
Joe
You can probably use some relays for that. You can drive a DPDT relay with one transistor, I used a couple for some channel switching once with something like this:
Earthscum
Actually, think about a transistor as being 2 diodes. If you look at an NPN, one diode (Base to Emitter) is forward biased. The other (Base to Collector) is reversed biased. All you should need is a 4PDT to switch the sets of Emitters between "IN" and pulled to V+ to reverse bias both diode junctions. Then you're only left with the leakage of the reverse bias. Not really sure if it would work, but in theory it makes sense.  ;D
You could use multiple 2P2T relays.
At some point it makes a lot more sense to build two Muffs and a simple A/B switch.
CodeMonk
LucifersTrip
always think outside the box
Perrow
I pulled a 27P4T rotary switch out of a KVM (keyboard, video, mouse) switch found in the recycling bin, and another massive switch from a printer switch.
LucifersTrip
Quote from: carboncomp on May 10, 2012, 02:43:54 PM
Quote from: LucifersTrip on May 09, 2012, 11:24:44 PM
They make rotary switches that are 12+DT, but they are usually pretty expensive and usually have many tiers, like:
http://www.goldeno.com/pictures/Img07256.JPG
http://www.ebay.com/itm/Janco-54-1917-19200-11732688-2-MOM-12PDT-Rotary-Switch-/190669125791?pt=LH_DefaultDomain_0&hash=item2c64c3f89f
if you haven't seen em, I had em in my last garage sale (#30, 51, 52)
http://www.diystompboxes.com/smfforum/index.php?topic=90624.msg846795#msg846795
Have you sold them all?
No, I still have those 3. I try to update right when something goes, so the last post in the thread should be up to date. #29 and 3 others from an older list are gone, but I think there are a few more I haven't listed yet...
