Author Topic: Center tapped potentiometers  (Read 3385 times)
« on: May 12, 2012, 01:46:13 PM »
Does anyone on this site have a lead to a source for 50% center tapped potentiometers? I've looked around the net and different manufacturer's data sheets but I'm drawing a blank exept for custom orders or roll your own.
I've opened a 16mm Alpha pot to see how it could be manipulated and have found that the resistive material is a bit too close to the outer edge of the wafer to attach anything with a lasting bond.
I saw a post here by Dan N with a tutorial on using a rivet to make the attachment but the link is dead.
Any Ideas?
Re: Center tapped potentiometers
« Reply #1 on: May 13, 2012, 06:04:06 AM »
Maybe connect the two parts of a stereo pot in series and use the point where you connect them as 50% tap? Behaviour would not be the same as a 50% tap, but -depending upon your application - this might work for you?
  • Poster2
  • Total likes: 716
  • "Digital? Any idiot can count to 1!" - Bob Widlar
« Reply #2 on: May 13, 2012, 09:17:56 AM »
I recently bought some dual 100K w/center tap off Ebay. I hope this link is still good;
Hope it helps.
Dead End FX
Asian Icemen rise again...
"Turn down the amp, strum harder."  - PRR
