Which pin is which? Foot Switch
Started by hovis, May 17, 2012, 06:06:50 PM
hovis
Hi all,
Complete newbie to diy stomp boxes.
I've been building a phase 90 using the PCB from tonepad... Its almost finished, I started to wire up the board to the foot switch but I've stopped because how can I be sure of which pin is which?
Have I got it right?
defaced
Today someone asked the same question on a different forum I frequent, so since I just saw it, I figured it'd be worth passing along: http://www.buildyourownclone.com/board/viewtopic.php?f=9&t=37664
With the lugs oriented horizontally (the way you have them in your build), the image in the first post is correct.  You can verify this if you have an Ohm meter.  Simply measure the resistance between two pins you think are connected.  The meter will either read less than 1 ohm if they're connected, or no reading at all if they are not connected.  Anything in between is reason for further inspection/suspect a faulty switch.
-Mike
hovis
Thanks, that's really helpful  :icon_biggrin:
Could you tell me how to connect the DC power jack? and LED? into the circuit.
Am I right in thinking that the 3 grounds go to the pcb?
mwynwood
If you're not going to worry about a battery, this way is pretty cool:
http://www.sabrotone.com/?attachment_id=594
Marcus Wynwood
My Build Blog
MarcusGuitar.com
kingswayguitar
test for continuity with a multimeter
Seven64
you are going to still put the ic's in that board right?
hovis
Quote from: kingswayguitar on May 18, 2012, 07:07:24 AM
done
Quote from: Seven64 on May 18, 2012, 01:57:37 PM
done
Quote from: mwynwood on May 18, 2012, 12:52:16 AM
Cheers for that link, it was really helpful1  :icon_mrgreen:
mwynwood
Marcus Wynwood
My Build Blog
MarcusGuitar.com
