Dr. Boogey Mods
Started by MarkusVG, May 21, 2012, 12:40:33 PM
size it to the size of your size of your trimmers  and your good to go...
MarkusVG
Nice :) thanks deadastronaut!
MarkusVG
Last question for now, I'm using the Gaussmarkov/MartyMart PCB layout. But the letters are in reverse, do I need to flip the layout to get it etched, or can I use it as it is?
J0K3RX
Quote from: MarkusVG on May 24, 2012, 09:38:42 AM
No, it's a mirror image.. after you etch it will read the right way on the board.
MarkusVG
Okay, thanks :) I'm planning on using it with a 9V adapter instead of a battery, does it need any redesigning for this? I will use a OneSpot adapter (I've had great experiences with this adapter).
that'll be fine!...i never use batteries.
just make sure you get a plastic dc jack...not a metal one!. ;)
MarkusVG
Okidoki :) Damn you guys are great! I've sent the PCB layout to the company here, it will be here in 3 days. Black PCB, with greencoat and fully tinned #NICE!
MarkusVG
Hey guys!
I'm wanting to replace C13 to C15 with ''Miller caps''. However, here in The Netherlands, most electronic stores havent heard about Miller Capacitors. Are there any specific types of capacitors that have the ''Miller effect''?
alfafalfa
Quotemost electronic stores havent heard about Miller Capacitors
Die bestaan ook niet !! = They don't exist !!
What is meant these small caps are used to create the same "Miller" effect like tubes have . It has to do with capacitance between plate and screen  and input and output. Look it up : just google.
Here is a very clear explanation:  http://www.aikenamps.com/MillerCapacitance.html
Hopelijk help dit !  = Hope this helps !
MarkusVG
Dankjewel Alfa ;) Zeker bruikbaar!
I have ordered all components, so I'll soon start building this :)
Thanks everyone!
WGTP
The Tone control from the SPITFIRE would work well.  Socket the caps for easy tuning.  ;)
Stomping Out Sparks & Flames
MarkusVG
I'm going to use the SWTC2 Tone control, simple but effective :)
Quote from: WGTP on May 27, 2012, 03:45:49 PM
yeah that would be good!... :icon_twisted:
