how would you add a 9v OUT to a circuit?
Started by pedaljunkie, May 24, 2012, 04:28:53 PM
pedaljunkie
I'm building a GuitarPCB buffer with a tuner out for a friend of mine and he asked if there is a way to have a 9V OUT jack to power his tuner since its on a Pedal Pal (side car for a pedaltrain board).
Would this be an easy mod?  If anyone could give me a bit of info, I would be much appreciative.
Heres the link to the circuit
http://www.guitarpcb.com/apps/webstore/products/show/2709436
If you're only going to power it with a DC supply, you just need to connect a second DC socket in parallel with the main one. This just takes the incoming 9 volts and sends it to the circuit and to the second DC socket, same as if you used a 9 volt daisy chain.
If you want to use a battery as well it might be a bit trickier.
pedaljunkie
Thats what i was thinking/hoping!  No battery..
Thanks!!
runmikeyrun
make sure the pedal he is powering off of yours has the same polarity, or it will cook his tuner...
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
