Whammy 4 post bipass mod issue
Started by EDLK, May 31, 2012, 10:29:38 PM
Quackzed
you can run a single insulated wire(ground bus :)) to your switch ground point, then peel off a 1/2 inch or so of inuslation from the other end of the new 'ground bus' wire (tin it) and attach that to all your shields. by using one wire on the switch ground it should be neater- less bulky, and you can peel off as much of the other end of the new ground bus wires insulation as you need to route to all the shields... im guessing all the shields are right where the leads are soldered to the switch, so you shouldn't need a long bus wire, just keep in mind where the bulk is thats keeping the pedal from closing and you should be able to find a way to get the bulkyness off the switch and onto the ground bus wire, and out of the way...
pinkjimiphoton
you can bundle the shields together, and run a short jumper to ground on the switch to gain some room bro. it'll still work the same.  :icon_biggrin:
psyched you figured it out!! well done!
Slava Ukraini!
~Jack Darr
EDLK
Cleaned up all the wiring
Works awesome, thanks to all who helped with this
Sheilded cable was the answer
Quackzed
roseblood11
Quote from: EDLK on June 05, 2012, 08:25:54 PM
Great! Pictures, please!!!
pinkjimiphoton
thank YOU  edlk!!
now i know what to do to fix MY whammy's issues..well done, mate!!
Slava Ukraini!
~Jack Darr
