OP Amp Big Muff cap values
Started by FastJunkie, June 02, 2012, 12:26:15 PM
FastJunkie
I'm doing the finishing touches on my IC Big Muff but I'm having some second thoughts about the value for C5 as per http://www.guitarpcb.com/PDF%20Files/BMP%20OP%20AMP.pdf
I'm going with the original values but I see the difference on C5 is a factor of 10, does this sound correct....?
DiscoVlad
Sure why not? :D
... Having the frequency response to be more scooped sounds pretty cool if you're playing unaccompanied, but won't help your guitar cut through the mix in a band situation. If that's important to you, then go with stock values.
